layout pcb
Ook thanks...
I'm sorry but I can only that someone will make
Ook thanks...
layout
thanks and regards..
god job sir,.. its verry helpfull...pcb for amp
warm regards
andrew lebon
loock hier
Sir do you have schematic diagram and pcb layout of this 4pairs class H amplifier can u share it because im interested to build this.
Thank you and Best Regards,
Nhor
hope this helps
warm regards
andrew lebon
hi andrew do you have pcb files for the smps?
god amp h900
Greetings sir, is there anything that can display pdf lay out,, interesting,
Gruß
loock hier
Gruß
+1
Copper braid or copper straps jumpers should be used. The picture shows how Ecler solved this problem in their powerful amps like PAM4100 and PAM6100. The pcb shown is actually from PAM360 but the same solution is used in PAM4100/6100 models.
Where did you get the Copper Rails? Thanks
hope this helps
warm regards
andrew lebon
hi andrew what are the voltages vh and vl on post #108
thanking you in advance steve
- Cheshtap Power Amp
