http://www.ti.com/lit/ds/symlink/tpa3118d2.pdf
Page 14. The resistors on the Sanwu boards for gain setting are : R27 (= R2 in datasheet) and R28 (= R1 in datasheet). That's all.
Irribeo added that there is an error in the datasheet. You can set the amps for 20 dB by just omitting resistor R27 (often but not always 75 kOhm on the Sanwu boards). The value itself does not matter much it seems when 20 dB (10 x amplification for those allergic to logarithmic) setting is chosen. This was acknowledged on the TI forum.
So to reduce the gain to 20 dB you just remove R27 and leave that space open or do you have to replace it with a jumper?
Using a jumper is a great idea!
Omitting (leaving open) is not the same a shorting.
No !
There's not room inside for an excessive amount of ccs circuits, therefore:
Undervolted 20db
Nominal power voltage, 26db
Maxed power voltage, 32db
The gain that you should set is likely to correspond to the power voltage utilized. That is typical, but just bear in mind that mine has not yet arrived in the mail...
That's right.
But it isn't a big mod to add whatever kind of jumper or switch for the gainsetting.
Jumpers for promoting short circuits aren't likely to be necessary. That bit with the switch is a much finer idea.That's right.
On some ampboards the gainsetting has very big effect on soundquality, not just on bass.
On some ampboards psu voltage has very big effect on soundquality, not just on treble.
See what you find.
edit: if you browse the web you can find several distortion measurements for tpa3116/18, some show dominant 3rd order, some show dominant 2nd order, for identical ampboards, the psu (not voltage) is the difference there too
See what you find.
if anyone wants ti 3118 goodness then tread carefully if you think the smsl 36a pro holds the answers...seems they have had a change of heart for 2015,or at least a change of chip...
??????????-S.M.S.L ?SA-36A pro(2015)? ?????????[TDA7492PE???] ( ????? ) - NorthFlatJapan ????? - Yahoo!???
Wonder why they needed a 30 watt fuzzbox? Was it really that much cheaper?if anyone wants ti 3118 goodness then tread carefully if you think the smsl 36a pro holds the answers...seems they have had a change of heart for 2015,or at least a change of chip...
So I was looking for a tiny tip for my Weller and they wanted $11 for one. I ordered this iron for $5 more and it comes with 6 tips (one is a tiny one for SMT) and it has variable temp, is very lightweight, heats up almost instantly, has a LED to show its on. Very impressed with quality and function for $16 with 6 tips. They are Hakko style tips which is a plus. Sorry for the OT but I think I found my SMT iron.
http://www.amazon.com/gp/aw/d/B014KBIB3M/
I agree and this had me worried as I bought one recently and had to open it to verify. Luckily I got the 3118.
surely you could just tell by the sound produced? lol
- Class D
- Cheap TPA3118D2 boards, modding them and everything that comes with it
