Cheap printed circuit boards starting with 0,0375 Euro / cm2
Shame I couldn't find your advert yesterday.
Just as an example what would the cost have been for 1 x 15 x 9 cm board to the UK.
I've just got to drill it today.
I can not understand you ..what you mean that " I couldn't find your advert "
Isn't look bad ( material is similar with CEM3 ...cheaper than FR4 )
By the way , how much was the cost of your attached board 150x90 mm ?
My pcb's released for others are also DIY.
For PCB150x90 ( your presented pcb) , the cost is 6 Euro / board , on FR4 ( fiberglass ) .....and 5 Euro on CEM3 ( presented pcb's on this support type in my post - yellow nontransparent support)
DRILLING IS INCLUDED. ( never mind the holes numbers )
As bonus ......also painted with transparent soldering flux and SILKSCREEN also as bonus.
FR4 has better behavior at soldering than other supports, like CEM , XPC ( your pcb )
Good luck to "drilling " .....and maybe ( if you agree ) ,you'll post here your drilled pcb.
All the best,
Mihai
£5.85 incl P&P but that was DIY.
OK, I'll forgoe the drilling. I'd like to try one of your FR4 boards. Can you make the B9A holes 1.6mm and the OCTAL holes 2.5mm diameter please.
Please let me know how you would like the images, I normally view the boards from the TOP, ie the component side.
Finished size is 150 x 90mm.
I'm not interested in silk screen.
Thank you.
