20x25x30cm with 15mm panel thickness?
Needs to be about 26 cm wide just to fit the A10 if you are using side slots.
about 26x40x19 for a classic golden ratio box
dave
The plans lack a material thickness.
When I used PDF to DWG converter with the plan it shows that the used material thickness was 19mm.
Not possible to say for sure, but it also seems that the middle plate which is dividing the cabinet into two chambers are opened just on corners - or it is just my imagination which is telling that...
