Here is how the finalstage looks 000webhost.com - free web hosting provider
I used TC429 for drives, they are strong enough to handle 6A peaks. I use them so in the near future probably i will want to handle more power on output.
Anyway now i have a little time for this, i am stil working on designing the amp.
Regarding the choper transistors, i too was thinking to use IRFB4227, they are probably the best solution for high power class D amps.
I will come back latter, now i gotta run to work
Cheers
IRFB4227's are very pwoerful but do need a lot of driving.
I used tc4420's for driving the gates but found I got a lot of noise on power down. A NPN/PNP pair is a better solution.
pls post your schema
http://forcedgifting.com/?ref=stewin
As per datasheet except pnp/npn gate buffers.
And overcurrent is set to be very high to stop accidental tripping.
- Class D
- Building a 1000W @ 8ohms class D amplifier from zero
