B1 Buffer Preamp
diyAudio Chief Moderator
Joined 2002
I have this one. Changing the Beta, Idss changes. Try to see what happens (if it is not the same already).
.model J2sk170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Betatce=-.5 Lambda=1.923m
+ Vto=-.5024 Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 Fc=.5
+ Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p N=1 Xti=3 Alpha=10u Vk=100
+ Kf=111.3E-18 Af=1)
Disabled Account
Joined 2006
Hi tanh, I havent simulated this circuit but I for one think it would display more h3 than second, playing around with values should make h2 dissapear. I dont think the guys that get h2 to be above have the exact same circuit as in the pass paper, and if I remember correctly NP himself said it would be predominantly h3.
Well I hope so.
I am learning heaps at the moment using LTspice - changing values or components looking at the effects, determining dc offset, bias currents, input impedance, and also looking at the distortion profile.
It has also been a source of motivation to try tweeking things where as before, I would be totally relying on ohers experience or guessing.
Anyway, I hope as you say it is predominantly H3, or all confidence I have in simulators will be lost.
Unless I can find the source of this discrepancy.
Joined 2002
I just run a B1 FFT measurement again. Second order is higher than third. Mine has +/- 10V supply and no coupling capacitors. This card has 0.007% residual THD and 100dB noise floor in the last octave.
Joined 2002
I will see near that when I will get my new EMU 24bit I guess. You must be using AP2? The main question is do you still see more second than third harmonic in your FFT like I do? I used 0dBV input, volume fully clockwise, about 3k card input Z.
Thanks Nelson
OK then hopefully I have made a mistake somewhere.
Can someone check the way I have drawn the circuit.
I am a little unsure about the signal ground/return and output ground/return, and the DC power ground/return.
Any help would be most appreciated.
thanh1973 said:
Thanks Nelson
You do not have things setup completely for an FFT with LT Spice. Try adding the following directives.
.tran 0 30m 0.1u
.step param C list .100u .10100u
.option plotwinsize=0
Test at 1000Hz.
If you want to learn more about LT Spice. Try the forum for it on groups.yahoo.com. I am unable to help you further. I just copied the above from an example I found there. It works for me.
Jim
Mr. Pass
I read a post by you that mentioned using the AP1 and some other attenuator after the source and before the amp with a buffer or pre inbetween. I cant for the life of me find it now. You talked about maybe having just a few different resistances to choose from before the buffer/pre and then after it to have, I think, the AP1.
Is this to help 'rectify' any source output/amp input impedance issues or what is the reason?
I think this was with a BOSOZ.
Uriah
Official Court Jester
Joined 2003
udailey said:
Mr. Pass
Uriah
AP1 is measuring gadget , almost capable of computing 42 .
we don't ( we - spoiled kids ) even need to know exactly what's that beast ..........
anyway - I can just imagine using it as attenuator :clown:
