yes, it is possible.some shape of signal contains geometry that increase acceleration of air particle. this is not new for me,it is used in military aeronautical and other (some are secret).
Preface of story:
During development of the DPA-400 (with PSU rips) I tried to get a lot of realism on percussion. when it was heard, it seems that we have achieved this performance perfectly, very fast attack on the sound of the bass drum.(with good spl)
To the latest listening tests, we found a significant warming of the woofer. At this point, along with other collaborators, it was ruled a fault on the amplifier, has taken the study of this phenomenon.
Theory :
Particle Velocity : v Particle Velocity is the distance travelled by a particle per unit time in a medium that is displaced from its equilibrium state by the passage of a sound or vibration wave. the units are m/sec. When applied to a sound wave through the medium of air, particle velocity would be the physical speed of an air molecule as it moves back and forth in the direction the sound wave is travelling as it passes.
Particle Velocity v = I/p = ξ·ω = ξ(2·π·f) = a/ω
where
I is the instantaneous acoustic intensity
p is the instantaneous sound pressure
ξ is the particle displacement
ω is the angular frequency
π is about 3.142
f is the frequency
a is the particle acceleration
In acoustics particle velocity is sometimes denoted by u
Particle Velocity Level : Lv = 20 log (v/vo) dB re 5 x 10-8 m/s - also known as dB SVL, sound velocity level
Particle velocity should not to be confused with the speed of sound.
It is obvious that I'm not changing the dynamic structure of sound.
so we are talking about eg. an envelope (bass drum).
The shape of this pulse, contains the parameters of acceleration.
10 people have measured up to 123dB SPL at 1m of bass drums (real drums)
Then, they measured with 2x800w max .. 115dB (118dB with 5000w JBL speakers system).in both cases, the timbre is not dry as fast as the original.
Independant of my job on Amplifier, this problem have an scientific explanations.
This is the test bed, we have equipped for these measures.
As soon as possible, put all the charts. and, reason becouse dpa-400 can increase the sound pressure at constant watts rms and speaker than another amp.
Preface of story:
Theory :
where
π is about 3.142
f is the frequency
This diagram illustrates the relationship between the geometry of the electrical signal and the pressure / depresión produced. a signal very fast (if it is reproduced with the same speed) can produce high sound pressure levels peak. as in the case of the bass drum.
Continue..
Continue..
After the measures as the pic "Current Test", the error is impossible.
I mean: we sent a continuous signal at 60hz (SIN) in MosAmplifier adjusting the gain for a clip, we measure 58vP (this is our reference amp, with very big psu). we set the DPA-400 for the same value (identical).
that's ok. Now we change the signal pattern with triple-burst. repeat the steps for one minute (ref amp and DPA-400). output voltage in both the amp is the same but the dpa-400 increased the output current. at this point with some colleagues from the CNR, we have tried to study the phenomenon.
Increase in current is also testified by the increase in temperature on the woofers. also, that during test, when the burst was on the DPA-400, he was a very different sound. (MDI has set up this laboratory measures in an anechoic chamber).
I can confirm in this moment: the woofer impendance change when in acceleration. this is correct, the mass changes in relation to speed.
the speaker and bass reflex determines the pressure / depresion internal, this is a factor in the calculation of the dynamical mass.
End, not all amps can follow sequentially the speed of a sound envelope containing accelerations.
I wait all the curves to show the differences between a mospower 700w (2R) and our DPA-400 750W (2R).
I can not show a company name of mospower.it's a prestige model big case.
Really strange that you get such different results, while the voltages are identical.
Also wondering about your model of changing mass as a function of velocity.
Isn't this effect neglectible under normal conditions?
A speaker cone of a sub might typically move with velocities between 1m/s...5m/s.
That's eight decades below the speed of light, so I would not expect that mass is changing in any noticeable way.
----Really strange that you get such different results, while the voltages are identical.
Depends on what we call as mass.
on relativity theory, you will come across rest mass and relativistic mass.
Rest mass does not change with velocity.
Relativistic mass changes with velocity.
A part this,I called "Mass" Mms - the mobile mass (g). (sorry for my english and...very absurd google traductor).
The friction is given by the diameter of the cone, the density of air particles and the resonance structure (a project of the box). this to calculate the electrical power needed. or inverse,that spl produces.
During the tests (they are still in progress with another speaker), I agree that the behavior is new (it all started with the heat of the woofer). Now, as you can not increase the acceleration speed, in addition to that determined by mechanical structure of the woofer, it is clear that the (r) decreases during acceleration (pressure/depression). I have not at this time all the test data.
the only thing certain now is that the temperature increases the woofer, listen, the drums are very hard and that ,speed of accelleration create a big instantaneus peak pressure that our we ear.
I do not worry, the truth will come out.
You didn't get my point.
The relativistic mass of a speaker cone, which moves with some single m/s is almost identical to the mass of a non moving cone. The difference is far in the sub ppm range.
Therefore I am not convinced that this is the key effect of your phenomenon.
mrel= m / sqrt(1-(v²/c²))
---You didn't get my point.
yes, I agree, I know these formulas (not in all). in my last post, I wanted to correct that "mass" in the "energy needed to accelerate an object",but ..what "friction"? ahah! I think may be the kinetic energy. if I remember correctly, in this case KE. but in this case back to the "R" that has to change. given that V on coils not change. So why change "R"?
On resistive load, Both amps have the same current.
very interesting phenomenon, change power only with speakers and fast signal.
with sinusoidal signal have little difference. amplifier was measured in all ways ... is perfect, clean output, no sub oscillation.
the measures we have moved, so it's not in my lab.
I'm sure we will have a physical explanation of the phenomenon.
you have an idea in the meantime?
I guess I would spend the next nights on the measurement of output voltages and currents in comparison with both amps, because it does not fit into my world that a speaker does something different while getting the same voltage. It is not likely that the speaker changes its parameters and draws more current when seeing the same voltage from a different amp.
May be a slight shift of DC operating point under certain repeated bursts or similar?
A slight DC portion would lead to both effects.
Hotter voice coil and changed sound.
...but I guess my ideas are not new to you and I can imagine your findings did also not fit into your world and you already have spend these nights in the lab...
Hi, I thank you ChocoHolic for time I've spent.
In fact, after the first 4 measures crossed, I did not understand anything. then (because I have a lot of work), some friends are doing all the measurements. some are physical CNR. yes, I agree that speakers not change "R" during acceleration. i know that can change the impedance in relation to the box, as frequency response. but that's another thing.
I suspect that the integrated psu (this is new topology, and is able to respond with "zero" theoretical loss at dc pinout) provides instant absorption peaks, can increasing the amplitude of peak. This dynamic is clearly visible on the tracks when ready, I'll put them on this thread. this is the only thing that would explain perfectly the behavior with burst (and not with continuos signal). not have other idea at the time.
remains, however, the theory that the instantaneous pressure produced is inversely proportional of the angle of the peak. This in theory would explain the change of timbre when we call "fast bass" on a good amp.
In fact, even if we have an amp with more watts, the bass can be soft and not fast rap. near to real drums.This is a nice realism that I have listen.
---Drums get that hard sound when clipped (or even with a fast attack limiter), and some DC is introduced in the process... No DC servo?
Amp has a fast limiter (developed in DC) but not a single pulse of drum snaps, if the first impulse is not clipped (natural, for a time). this is my special alc present on all amps. but in this case, modulated bursts about 90%. (then not square)
DC servo, yes, the modulator has a loop through part of the NFB (filtered by a sub-rc). (I used two NFB) in the series Amp. DPA-400/600. the latter is widely used for bass guitar with enthusiasm .. (Attack, high harmonics of the string, etc. ..), I mean, amplifier product without problems in two years.
Pending the measures, I think that the psu to the DPA-400 has been pushed to get a good realism of percussion, so it seems the easiest answer. or the "R" for factors that do not know, decrease during acceleration.
few more days and I'll know.
The tests have focused on psu (for heating of the coil of the woofer), this measure of piece of music has been performed by changing the type of power supply, on the same amp.
The graphics show a segment of the same captured file.
the probe was added to the amplifier output (resistive 8R).
The acquisition started with the trig. the start of the song, repeated by changing the power supply.
Internal: power supply of the A-400 integrated amplifier.
external: 600VA toroidal high flux, with 2x68000uF +4 x470uF and BYW29-200 fast diode (8x).
Only one comment:
During the sound, as opposed to as many people think, the difference increases in relation to the presence of the transient. (the faster the modulation of the current, the greater the drop in voltage). this means that the bulk capacitor on the power supply unregulated, does not do the work that we believe. completely changing the angle of the peaks, as you see also, regardless of whether the power is high, or in the range of 50w peak
Only one comment:
I apologize for my English, I am sure that in the short AudioPower shows this new amp (also for diy version), showing this new research directly on the site, complete with all the measurements.
in summary, we show that the drop voltage(on psu) does not have a relationship only with the loss of power.
the envelope is changed right where expresses the character of the musical instrument.
In fact, if we reproduce a sound very close to the geometric characteristics of the original envelope, we get an spl closer to the original instrument (with less power required), and obvius, in fidelity as the dynamics of musical instrument.
"Closer" mean that is not possible reproduces same spl of musical instrument's.(in relation to the same energy imprinted).
the first reason is phase of emission of the pressure/depression, plus inefficient transducer that is the loudspeaker.
Hi, The DPA-400-F1 diy version.
Simple... ready and complete to drive a nice pair of full range speakers as Magneplanar or B & W or other models with reactive load between 2R to 2.7R without perceptible distortion or fatigue in the range of 200 to 730W output.
not only a transient, may exceed 730W with the APC system, this amplifier corrects in real time the power, even if the load at that instant is 1R, the output power remains 730W without additional thd. (this system is activated below 2R) This lets you hear is full and clean orchestral envelope.
(some musical instruments in the presence of crossover in the speaker, generate extra absorption, creating audible thd.
we usually we lower the volume in this case).
at end...this amplifier (after one year of testing) is also indestructible
P.S. this in photo is one for my lab, so not have label on alluminum frame.
some additional info.
There are 3 versions with different setups (F1-F2-F3) with different prices.
This idea allows, according to use, better performance.
the smallest power is the DPA-400/F3.
F1-F3 are for audiophile use.
F2 is for guitar bass, sub, musical instruments with power output 600w(4R) . All model not need fan.
I'm sure I can say that in this moment, the DPA-400 is the only amp that can offer a dynamic uncompressed (or not adds compression to the input signal)
the acoustic power will seem like double (if the speaker holds up well) hehe!
Good question (already received from others via email).Very interesting the F2 version (I'm a bassist).
But what is then the difference between the DPA-600 (already present at AudioPower) and this (new) DPA-400 if the F2 version is 600 Watt @ 4 ohm?
Roberto
The DPA-600, already offers new performances just used for bass guitar, as well as a high-definition (feels the touch of strings) just before the "big hit", which is very popular with bass players (in this amplifier is repeatable to each shot), this has been well studied and is a big difference compared to competitors. but .. Power Unit of DPA-600 requires a fan (although its speed rotation is controlled by the temp.), but for a few millimeters, does not allow the mounting 1U case.
second reason, the F2 has 30mm high, then it can be revolutionary (even with extension up to 750w) if mounted in a case very close to the size of the module.
AP perhaps have one project in mind at short.
Also, this new versions have some special components oversized,so the price is also higher than the DPA-600.
- Class D
- AudioPower (DPA-400) Sound pressure improvements?
