FifoPi Q3 works directly with DSC pure DSD DAC
FifoPi Q3 has both DSD_EN and MUTE outputs (isolated), so it can run a DSC pure DSD DAC directly.
I have one of this DSC DAC in my system. It works great with FifoPiQ3.
FifoPi Q2 doesn't have this DSD_EN output, so it may have problem working with the DSC DAC.
FifoPiQ3_DSC by Ian, on Flickr
Ian
Ian
Good News,
Dick from Audio creative (Link to their Site) tested the new Q3 with the DIP-8 size Tentlabs XO clocks and used a DIP socket in between which is a great and clever trick to overcome the fact Ian moved the middle pin away in the new version. Below the DIP Socket he soldered two wires from the clock to the outer pins.
This combination works sound wise great with the DDDAC1794 setup – so good to know for everyone liking the Tentlabs XO clocks or even having them lying around from other projects
You could buy it at audiophonics.frHi,
i need order FifoPiQ3. Could you tell me price + shipping from canada to europe and estimated shipping time? Thank you for reply.
Today I have done of the best upgrades on my dddac which have Ian’s fifopi reclocker. Accusilicon 45 and 49mhz is doing the job on fifopi. I have bypassed the 3.3v regulators on fifopi and my linear psu is from diyink, with r-core trafo and LT-3045 regs.
The upgrade is to simply put an 3.3v UCconditioner from iancanada between your psu and fifopi. Everything is sounding better than before. I will go so far saying this must be the best «tweak» one can do if you have fifopi and want to upgrade it to a new level. Highly recommended.
Aren't they favorably priced if you buy it in the group buy?You could buy it at audiophonics.fr
Don't know. I always buy via audiophonics but I live in Europe and delivery is fast[emoji4]Aren't they favorably priced if you buy it in the group buy?
They are, but GBs usually require some patience 😀
I got my Q3 fifopi directly from Ian within one week. And it is a bit cheaper than Audiophonics (and also Ian will probably earn a bit more from direct sales )
Good News,
That's a very smart solution, Thank you so much for sharing!
Regard,
Ian
StationPi V2.0
StationPi V2.0
V2.0 New improvements:
1. Has an opening for RaspberryPi heat sink
2. Support audio HATs in both orientations
StationPiV2.0 by Ian, on Flickr
StationPiV2.0DigitalTransport by Ian, on Flickr
Ian
StationPi V2.0
Ian
[emoji106]I got my Q3 fifopi directly from Ian within one week. And it is a bit cheaper than Audiophonics (and also Ian will probably earn a bit more from direct sales )
Hi Ian and all,
My first time GB, sorry for the question.
I reply the post for Q3 GB, and what should I do now?
Is there any form to fill?
Has the GB began?
I know there are already stocks on Audiophonics, but I am not in Europe, kinda far and seems a bit higher in price and shipping.
Ian, I wrote a mail to you about volume buying, looking for your reply, thank you very much
Has the GB began?
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
