Quick question for Ian.
I am working on getting a very high spec XO clock 45 and 49 MHz series (for these frequencies -115dBc at 10Hz) but need to define the OE pin. Now the OE pin will enable the output at logic HIGH or pull it Low when the OE pin goes LOW.... So, this XO will not be able to do a tri-state output. Hence I assume this will not work with the Q2 version FIFOPI ? But will on the Q3?
Correct ?
Alternatively I can leave pin 1 floating
What would you suggest for the FIFOPI Ian ?
I see Ian stopped posting anything since his last post Oct 1st before that daily posts almost. Anything wrong?
sure, I noticed. But you cannot stack them easily on a FiFoPi or whatever other PCB. That is the gap I am currently trying to close by still getting a better clock (-115 versus like -100 what I found right now) than what you can buy right now in DIL14.
I see application for both ways
I believe you put the little squarer pcb on FIFOpi and run a cable to the WTMC.
That's right, stacking the oscillators on the FIFO is a bad idea, they influence each other and emit RF.
Just as it is a bad idea to stack the FIFO on the RPI that generates a lot of EMI/RFI.
Maybe correcting firmware for 1541A use with his I2S to PCM boards ?
Can't find the ufl to dip adaptors in the GB , can you point me in the right direction please .Yes, I do.
Regards,
Ian
Good to see you're back Ian,
could you please answer my question I posted before? that would be great
thanks
ps: which was:
Correct ?
thanks
ps: which was:
Correct ?
StationPi finial
https://flic.kr/p/2jXgEje
StationPi by Ian, on Flickr
Assembled
https://flic.kr/p/2jXgEmo
StationPiAssembled by Ian, on Flickr
Ian
Okay, so when will it be available please?
Hi Ian,
Will we have the chance to solve some problems at the source with Iancanada made new Pi board somedays as Allo did please? We know that the fifo helps a lot but is not a 100% proof isolating.
As Hanze Kroyne asked. any chance to see a futur improved i2stopcm board for tda1541 lovers or an usb to pcm board a la JLsounds with newest tricks about power supplies. Caps. etc ?
All that boards around a bad born Rpi for audio purpose is...something limited. That is true for all the people trying to make Rolls Royce around a vacum cleaner motor which is of course the Rpi while the R&R is all your good work ...as others, your not the only one of course. But as you have always an advance so I ask
I think I'm in for the StationPi just for the ingenuity alone. I just purchased an 8GB so I can have a 4GB RAM buffer. Should be easily justifiable.
I avoid proprietary RPi solutions (Allo) as software support is flaky or can get flaky over time. Now that the new Compute 4 module is out, your going to have to pour money into another new proprietary product? No thanks, I'll stick to open hardware / software.
So cheers to Ian for your hard work in releasing the final StationPi. It provides us with a option to isolate the RPi.
i have an early stationpi from Ian and i can say that it definitely works on my setup. I don't have a measuring equipment. This is just based on listening with and without the stationpi. with the stationpi, the sound is by far a lot cleaner, more 3d, more alive, more dynamic. I can say that it sounds closer to analog.. I cannot go back to rpi4 without the stationpi...
this is using rpi4, ians fifopi q3 with crystec clocks then spdif to primaluna evo 100 dac..
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
