Updated list
bfg4wd (1x A40 set)
meanman1964 (1x A40 set)
mlloyd1 (1x A40 set)
pchw (1x A40 set + 1x P30zf set)
mos (1x A40 set)
asuslover (1x A40 set)
Kay Pirinha (1x A40 set + 1x P30zf set)
Junie (1x A40 set)
Junie, I had only two P30zf set left and Kay Pirinha was first. Sorry.
All sets are spoken for. If there more interest for the A40, I might add another 10 PCBs and try to lower the cost some more but there will be a point where customs will hit me and it might not be less expensive. Let me check on that but for now all set are spoken for. I'm just awaiting alex_mm's new gerbers.
Do
bfg4wd (1x A40 set)
mos (1x A40 set)
Junie (1x A40 set)
Do
I am also interested about the shipping fee to Romania. Thank you!
Hi Mos,
In a padded envelope with air shipping (no tracking) it will be 4$ more for you. Still very affordable.
Do
Hi Pinnocchio,
please count me in for a stereo set of P30zf.
Many thanks!
Hi touchdown,
I'm out of the P30zf, I only had two sets left, sorry.
Do
Sorry , im a little bit lost in translation here, what preamp are you guys talking about?
Hi asuslover,
The P30zf is a preamplifier design by Apex and the layout is from Alex_mm. You can find most Apex designs in the thread:
http://www.diyaudio.com/forums/solid-state/292226-directory-apex-audio-amplifiers.html
Do
Hi pinnocchio,
I would be interested in a set of A40 and a set of P30zf. (or maybe more depending on $$)
Why don't you include the interest in the P30zf, and have some more boards made???
Thanks,
Myles
Hi Kokanee,
I did not wanted to turn this into a GB since it is a lot of work to mail everything out and all I really wanted is to sell the extra PCBs I had at my cost. The A40 amplifier layout has been build and tested by users already but the P30zf layout from alex_mm has not yet been tested but it has been verified by himself. Because of this, I'm not to inclined on making another batch before someone test the layout. If there's enough interest and some people are ready to take the risk (although quite small) then I can think of running a second batch of the P30zf. I'll see the interest and put you in the list.
Do
Updated list
A40 Amplifier
bfg4wd (1x A40 set)
pchw (1x A40 set + 1x P30zf leftover set)
mos (1x A40 set)
Kay Pirinha (1x A40 set + 1x P30zf leftover set)
Junie (1x A40 set)
aradan (1x A40 set) - Potentially if we can reach 30 PCBs
Kokanee (1x A40 set) - Potentially if we can reach 30 PCBs
P30zf preamplifier (untested layout but verified by alex_mm). This is just an interest check to see if there's enough people for another batch of PCBs.
touchdown (1x P30zf)
Kokanee (1x P30zf)
A40 Amplifier
bfg4wd (1x A40 set)
mos (1x A40 set)
Junie (1x A40 set)
Kokanee (1x P30zf)
I might also have a couple sets of the Very simple quasi complimentary MOSFET amplifier found here:
http://www.diyaudio.com/forums/solid-state/255427-very-simple-quasi-complimentary-mosfet-amplifier.html
I ordered 10 PCBs not yet received and don't know what they look like until I see them. But it has been tested by several users. I believe I might have 3 sets available but need to go through my emails and PMs first. Should also be white with black silkscreen. I have to look at my specs and cost for this one.
Do
Do
could anyone please tell us which schematic the A40 boards actually refer to? The schematics and the silkscreen given here don't correlate, as the first one shows components that aren't included in the latter one - and vice versa. So it would be a bit messy to create a valuable BOM.
Best regards!
Best regards!
Here's the file that was given to me by alex_mm
HI Pinnochio,
I'm a little bit confused now, as your schematic seems to be identical to the one shown within the abovementioned post #4148. The silkscreen there shows some more and other components, e.g. three caps in each supply line, an inductor of unknown value in the output etc.
Presumably not a major issue, but I'd like to direct it to the right way.
Best regards!
Best regards!
Updated list
A40 Amplifier
bfg4wd (1x A40 set)
mos (1x A40 set)
Junie (1x A40 set)
nik_d (2x A40 set) - Potentially if we can reach 30 PCBs
A40 Amplifier
bfg4wd (1x A40 set)
mos (1x A40 set)
Junie (1x A40 set)
