An Amp Sonics side-thread
vasyachkin said:
first of all, damping factor can never be too high. ideally it should be ininite.
Dave has already covered this. Nelson Pass has covered it even better.
vasyachkin said:
you do have a point that if you run an AB amp at 0.1% of its power it may have poor distortion and noise performance there ... but at 10% of its power an amp will typically have better performance than at 90%.
So with my high efficiency speakers, down in the low power region the amplifiers will spend most of their time working in, the AB design will sound worse. Wow, I've only known that for 20 years.
vasyachkin said:
yes there is still every reason to build efficient speakers but there is no reason to use 2 watt amps.
At about 104dB from >200Hz, why do I need more than 7W in a modest room? A large SS AB amp isn't much more energy efficient and sounds worse.
Currently <200Hz is 35W AB, but will likely be replaced sometime in the future with a switchable 20/40W class A design as I have all the parts on hand.
Disabled Account
Joined 2008
Brett said:
I have my own PA's, all built by me so I understand. Please explain the relevance to domestic reproductive systems.
There are many superbly designed and implemented class A amplifiers out there.
Build efficient speakers, then the size and class of the amplification becomes a much smaller issue, with far fewer compromises. By efficient I mean >96dB, preferrably 100dB. Compromise is in size and sometimes cost.
what i meant regarding home versus PA systems is that at home its not a business so its not about the bottom line. lets say you determine that you need 50W per channel, then there is nothing stopping you from using a 500W per channel amp and you can forget about clipping. you cannot do this for PA because then you will have to explain why you're wasting money that is not yours. so the PA amp i have has a "soft clipping" option (switch) for example, but in practice i don't need it because of the headroom.
as far as building 96db to 100db speakers my position is this. all things being equal i will always prefer a more efficient speaker, but if i have to make any compromises in performance to get the extra efficiency i will not go for it. there are 8000 watt amps (Crown I-Tech, class D) that sound good enough to cover bass in an active system and there are slightly less powerful amps, say 7000 watt (QSC Powerlight, Class H) which are good for covering the rest of the frequency range. as such 96 to 100db efficiency is a luxury, not a necessity.
So does your class A amp also double as a toaster oven or room heater?
Just kidding, really.
If I could have two 40W all class A amps for normal listening, I would. I agree that in a normal entertainment room, 40W would be adequate for 99% of the time. And ceteris paribus, class A naturally has less distortion than AB or C.
Why two? I normally run a DSP.
It depends on where you're willing to compromise. I would rather have a lower SPL, through better amps into more efficient speakers, than dynamic power compression with AB amps into less efficient speakers. Been there, done that.
vasyachkin said:
as far as building 96db to 100db speakers my position is this. all things being equal i will always prefer a more efficient speaker, but if i have to make any compromises in performance to get the extra efficiency ... {snip}....as such 96 to 100db efficiency is a luxury, not a necessity.
Depending upon how the lower eff system is implemented, there may be a whole raft of compromises. I've posted on it before, and I just can't be bothered rehashing it today.
Luxury, no. I build these systems both for the enjoyment of listening to them and the experience of the build, so they provide pleasure and other benefits on other levels, such as increased knowledge through experience and research. These things are not luxuries in my universe.
vasyachkin said:
i think my amp has DF of about 500. i believe DF is achieved through large amount of negative feedback ... and i happen to think NFB is not evil.
Not in the real world it won't be. Add connectors and even modest cables and it drops significantly.
Why two? I run a DSP.
Heat is not an issue. The room has good natural ventilation.
What's the DSP got to do with it?
Single amped, in my system, it would be more than enough.
I'm quad amped, or will be soon;
20-60: SS PA amp
60-200: 35W tube AB, to be replaced with 20/40W class A
200-1k5: 7W PP class A tube
>1k5: same amp.
All of this was built, except for a few passives, with the parts I already own.
Disabled Account
Joined 2008
well if you count the resistance of cables its going to drop from 500 to about 20 indeed
and if you count the resistance of the voice coil then it will drop to below 1
what is your point ?
DF is certainly not the parameter on which to judge an amplifier and yet high-tech amps generally have it higher. i believe Crown I-Tech has it at about 1000 or more.
i would agree that DF of about 20 is enough in practice, but i would feel safer buying an amp with DF of 1000 because typically only very high performance amps have that.
Brett said:
Almost all SS AB amps sound the same to me, whether an old Rotel or yamaha, or the Quest, QSC,or Yamaha high power designs I use in my PA's.
Under double blind conditions?
Brett said:
Generally, not that great, especially when you're running very high efficiency systems.
Really? Earl Geddes used a $150 AB Costco Pioneer to demo his rather efficient Summas. Tom Danley uses AB as well with his even more efficient Synergy Horns. I wonder why they are not hearing such fidelity losses as you? Here is a thread where Earl discussed his measurement methods
Geddes on distortion measurements. Are you using such measurement techniques? Maybe the ones like Bob Cordell uses?
Brett said:
Distortion is worse at low levels with an AB amp (any type) because nonlinearity increases areound zero. High eff speakers make this much more obvious.
That is a sweeping generalization. There are both good and bad examples of AB design. Claiming that crossover distortion is audible listening to music using every AB design would be unsubstantiated. Unless you have data to show me otherwise.
Brett said:
As well as doing tests, I've also designed, built, tested and measured about a hundred amps over the last few years, so I feel I have some insight into why there are differences between them.
Please share your results with us. Nothing against peer review of data I hope?
cheers,
AJ
cheers,
AJ
This belongs in the Audio Asylum's propeller head ward.
Disabled Account
Joined 2007
planet10 said:
Can you show us the distrotion spectrum of your amplifier? I bet it has lots of ugly high order components....
dave
Hi Dave,
For my own information here, do you mean something like this:
Well, as you're connecting to a speaker that includes cabling and connectors, it's far more appropriate. It's rrelevant what the DF measures with a test resistor across the amplifier terminals.
Many were. And as I already own all the gear, my biasses are substantially reduced on the non-blind tests.
If you note in the linked Geddes thread, I'd mentioned using an HP spec an years ago to try to do something similar, but couldn't get SNR low enough for good repeatable measurements. When I have the time (I'm going back to school this year), I'd love to examine this further.
Because someone finds something adequate for the task, doesn't mean there's not other ways of doing it, some of which may be better.
I think it's on the mark for the majority of generic AB designs. Show me where it's not by giving some measured examples at low power where I would use it.
My data is all in hardcopy in notebooks and I have no interest in spending the time or effort to make it electronic for your review.
planet10 said:
And can you show valid double blind tests that show they are all the same?
Can I show valid double blind tests that they all sound the same to Brett?
planet10 said:
Or scientific proof that small amps aren't better?
I am to present scientific proof of your purely subjective contention?
Then move or re-post it there yourself.
cheers,
AJ
Disabled Account
Joined 2008
dave
i dont have such data. however why assume that if an amp has less overall distortion that the distortion must be uglier ? and why assume that if an amp has lots of distortion then it must be euphonic ?
thats like saying that a blonde must be dumb or a person with thick glasses must be smart.
i will readily agree that a class H amp will have much uglier distortion than a class A amp, but this has nothing to do with amount of NFB.
as i said before i have nothing against inherently linear class A amps except that they're not very practical. if i could choose between two amps of same power, same price and same THD i would get the class A ... but i will never be offered such a choice :)
if i have to choose between a class H amp of the power i want and a class A amp with 1/10th the power that i want, then i will go for the H.
frugal-phile™
Joined 2001
Yes... looks like a PP amp with little or no 2nd order, but a fair amount of 4th and some higher. Anything above 3rd the ear really finds objectionable, and the lack of 2nd means the 3rd isn't as well masked. An ideal spectrum would have some 2nd, a bit less 3rd, and vanishingly small higher order components.
dave
Disabled Account
Joined 2007
dave
Thanks,
Looking at the scale the higher harmonics are about -100db, including the 4th. That's a long way down.
Are you sure this is hard to listen to?
