Many thanks to Acko for the assembled S03! I have never seen a parcel that was well packaging with such diligent!
Big tick from me!
Thanks again.
Chanh
Big tick from me!
Thanks again.
Chanh
Pleasure! precious cargo
... back to business, your current setup has set a very high bar and my minimum expectation is for the SO3 to better it given that it has isolation and re-clocking that eliminates jitter with reference to a low phase noise clock. Also, as the clocks are 45.xx/49.xxMHz types you should only use it with BBB or similar in full synchronous re-clocking.
bare pcbs from previous batch all sold out. Need to re-order and min qty applies from factory.Is the S03 bare PCB still available ?
no Amanero mounted or suppliedAlso the price is without the amanero board ?
This is very bad news Acko...
I was just planning to built a new S03 for the BBB.
Any chance to get available soon?
Regards,
Enrico
Regards,
Enrico
I will check with factory tomorrow and advise
S03 bare boards. No components mounted or supplied
Min order 50pcs
Price each $25
If interested please add to this list
Acko X10
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
if we could not get minimum order any possibility to have a lower order qty but at a slightly higher price ?
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
If the list stagnates after a while ~30days I will advise other options.
I will not keep you all waiting too long
Hi Acko,
What brand/type of clocks are you using for the assembled S03 ?
Standard build: NDK NZ2520SD Dual Ultra low phase noise oscillator with 45.1584/49.152MHz or 90.3168/98.304MHz options.
other brands and options possible if preferred
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
JimS x 1
Report Post
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
JimS x 1
Report Post
EDEL NMR Pricing
Hopefully Acko won't mind me posting this info on his thread; if it looks as though there is mileage in it we can move it elsewhere.
OK, I got the information through about the Edel Network Media Renderer boards;
Network Audio Renderer | ABC PCB
The cost of a single board works out at about $485 (£302, 383Euros) before taxes and shipping. At 10 boards the unit price falls to about $460 (again before taxes and shipping) and there are further price breaks at 25 boards and above.
So the boards are quite expensive and you would need to buy a lot to get a significant reduction in the unit price. Does that sound like a viable group buy - I'm not convinced and it would seem to be easier to just buy a single board if you want one - what do you chaps think?
The information I received gives the prices in Swiss Francs and the numbers above are based on today's exchange rate.
Ray
I've queried availability and pricing via the website. I will report back when I know more.
Ray
Ray
- Group Buys
- Amanero Isolator/Reclocker GB
