Alpine 3502 not turning on?
I'd suggest an MJE15030. I used them a lot as drivers and never had problems with them (oscillation, distortion, bias problems...).
Note that the pin configuration is reversed so you have to install facing the opposite direction.
If you have something on hand, try it.
If you can, try to measure the rail voltage. You should be able to measure it in a second or so if you connect your meter before you power up.
