Aleph-X Compact PCB Group Buy
PeterLeest said:
Hi Bruno,
I received the boards, very nice, thank you.
In post #65 attached circult, VR101 is 50K, however, I found in another link, the VR is 200 ohm. it could be to typo error.
http://www.kk-pcb.com/alephx.html
For the rectifier board, what is the value of R & C (example C1 & R1) ? Also, do you intend to use MUR30 (MUR3020WT) or MUR1560 for the Aleph-x ?
regards.
Hi all,
it's true, the value of VR101 is wrong, as it has been pointed out also in This Thread
Here's a copy of my answer to that:
"Hi all,
that is the schematic I posted on the Aleph-X PCB group buy thread.
It is directly taken from KK's Site and I've just redrawn it to create the PCB.
Now, the value of VR101 is wrong (my BIG mistake! :bawling: ), it really must be 200 Ohms, as Grey pointed out. I apologise for this mistake.
As for R103, the value of 360 Ohms is exactly the same as on the original schematic I mentioned above. I do not know if it makes too much of a difference with Grey's original value of 330 Ohms.
With VR101 set to 0, the equivalent value of the parallel of R103 and R104 is 203.85 Ohms with R103=360 and 193.875 with R103=330 Ohms.
With VR101 set to 200 Ohms, the equivalent total resistance is respectively 255.53 and 249.1 Ohms.
I leave to the experts (I'm not one) to judge whether it's preferrable to set R103 to 330 Ohms or to leave it as it is. As far as I know, several Aleph-X have been already built following this schematic and they work..."
Here's the corrected schematic.
Bruno
  • alephxcircuit.pdf
regards.
Hi all,
the exact values of R & C on the rectifier boards depend on the diodes used, as well as on the transformer. A commonly used starting point is R=100 Ohm, C=100 nF.
Jim Hagerman (Hagtech) wrote a nice tutorial about "snubbers": Snubbers
As for the diodes, it depends on how much power you want to squeeze from your amp. For a low output power (20-30 W), MUR1560 will be enough, otherwise better use MUR3020WT or equivalent.
Bruno
Hi lscangus,
the source resistors are calculated as follows:
R=0.5V/Bias current in each FET.
This is a nice tutorial.
And this spreadsheet will help you calculate all the important parameters of your Aleph-X.
Bruno
P.S.: Lately I've been very busy with professional and private matters, and I had to put aside my hobbies (including this one) a little bit. Please bear with me, I will try to answer all your questions as soon as I can, but please, do not get upset if I happen to disappear for a day or two every now and then...
Carondimonio said:
Hi lscangus,
Bruno
What do you mean by 0.5V/bias current?
Angus
Hi Angus,
the real supply voltage will probably be a few volts lower when loaded, say 18-19 V. This is the voltage you should take into account when calculating the output power.
As for adjusting the supply voltage to a lower, desired level, you could use for example a resistor (with adequate power dissipation) between two filter capacitors, improving also the ripple. Just bear in mind that you will waste some power...
Bruno
Carondimonio said:
Hi Angus,
Bruno
thank you very much.
So, what is the VR on the board for?
Angus
eapavant said:
vr1 sets the bias of Q3, vr3 sets the bias of Q8, vr2 is used to control absolute dc offset. this page might help some.
http://www.facstaff.bucknell.edu/esantane/movies/aleph-x.html
He has lots of good info all in one place about the aleph-x.
So, all the components i need is written on the Aleph-X compact PCB, and i do not need any other adjustment to the value of the components except the resistor on the fets board. and that resistor is 0.5/BIAS per fets.
So i am using 8A as my BIAS and i am using 8 fets per channel. so it will be 1A per fets. so.. 0.5/1, = 0.5Ohm. is it right?
I am using about 17V as my rail voltage. so is it better off using IRFQ044?
Angus
Update
Hi all,
just a quick update:
the new rectifier boards have already been shipped to me, I should receive them in a couple of days. Once I get them, I will check them thoroughly and then, if everything's OK, I'll forward them to all the members who ordered them/got the wrong ones.
One more thing: I still have some Aleph boards available...
Bruno
