Does any have any of Peter's J boards they would like to part with?
Thanks,
Greg
I asked first.
Patience grasshoppers,I believe earlier in the thread Peter mentioned once a X has been successfully built and he is satisfied with it he will run some more. I have always wanted to build a higher powered X amp but was a little daunted by the fiddling required to get offset to acceptable levels. If this one works out I will have to build one.
Bill
Bill
Bill
Im the same, thats why I chose to build Cheffs UGS Power, it seems to be more stable and reports are it sounds good. I also like that it can deliver more than its bias current. Im surprised more poeple didnt buy Cheffs boards actually.
BTW I am not sugesting this is not a good project, I bought my UGS boards before this GB
Bill
So then those with boards, get to building! Chop chop.
Bill,
The offset issues have always been a concern of mine.
The UGS boards were only offered in the French forum if my memory is correct. I to would like to have tried Cheff's circuit.
This J aleph is still considered one of the sweet spot Pass amps.
Tad
Yes they were part of a french forum groupbuy, but I got some through posts on the thread here.
Resistor recommendation
Peter,
I have finally gotten around to populating your Aleph J boards and ordered Vishay Dale RN65 resistors, only to discover they are Huge! I read your post somewhere that you recommend the Vishay Dale CFM 50's, but these are nominally rated at 1/4 watt. Are CFM 55's better suited or are 50's indeed OK? Thanks.
Peter,
The boards are presently sold out. When X version is tested I may do another run, if there's enough interest.
I've missed 1st run too...
Peter, please count on me - sooner or later (2 stereo sets + 2 sets PSB)
Thanks for your effort & Cheers!
Agree, but do you have any idea about motivation?i think we have to motivate those people with the jx boards to get started on there build !!!
Me too...I was going to do a J-X as it fascinates me.
Till then the following reading (DIY Audio Projects) is maybe interesting for you (& DIY Aleph J-X community)
Cheers!
- Group Buys
- Aleph J-X pcb group buy
