EUVL said:> even 27 can be fine ;
You probably have not been listening to Mr. Curl on the Blowtorch thread.
Whether the JFET will blow at 27V is one thing, whether it still operates properly is another.
Patrick
EUVL , gimme a break ;
if it works on 24 , it will work even on 27 ...... but you must always count on +10% in mains voltage . that is where is real danger , not in squible about tiny fraction of lesser performance;
if I must pay price as usual to collect knowledge in mentioned thread... that always leave bad taste in my mouth .
man can resort on L input filter if xformer in case is on high side , voltage wise .
or burn few volts in R part of CRC filter
whatever
if you wanna comment something - ask Papa why he isn't cascoded little critters
My Aleph J - modified A5 PCB.
B.L. said:My Aleph J - modified A5 PCB.
This type of horizontal layout is really nice.
One thought, could the distance between the 2 output sections of MOSFETs be increased to better take advantage of the heatsink? Having the actual dimensions of this board would be helpful to judge.
Having space for the 2 additional output MOSFETs is a nice option for higher biased version.
In both board designs above it's great to see the input and output sections on one board rather than 3.
Just my $.02 worth.
Nice work guys.
-David
GRollins said:I must say that I'm not a big fan of running semiconductors at their rated limits, much less over.
Grey
me too .......... but that was not a question .........
that's same as using gas toob at max current .
looking in devils eye
Isn't distance between output sections enough?
B.L. said:output sections enough?
Not enough for 100 watts, imso.
HBarske said:Cleaned up a bit, we're slowly getting towards something useful:
Bottom layer pdf: http://www.hb001.de/aj_pcb3.pdf
Really nice work, Mr Barske
Grey
Me too!! Not mentioning; recommending it to the average DIY'er
Thank you very much, Steen. Here's the latest version:
Doubled the power resistors, so 1R/2W types can be used (much easier and cheaper to get over here), added two decoupling capacitors, increased the space between the output transistors, and did some other minor modifications. Pcb is now 100 * 100mm. If anyone's interested - here's the bottom layer pdf: http://www.hb001.de/aleph_j5.pdf
I am curious about that too.
I had my blue aleph mini boards cascodeded briefly, and listening in mono I noticed the detail was amazing. But it went POOF the next time I turned it on, and the jumper wiring I did to cascode it was too much of a PITA to swap out the jfets, so I didn't keep the cascode.
But I am working on a cascoded aleph board -- with the intention of becoming a respectable citizen by doing away with the blue boards in my mini-a.
JJ
Right on.
And I was trying to point out that even the device would survive the breakdown voltage, it would have so much leakage that it would no longer behave as it should.
Not that everyone cares to know ......
Patrick
Right on.
Patrick
- Aleph J Schematic
