3pcs of CL60 in series , even better
I think you need a little resistance in series with each thermistor to keep things even, like 0.47R .
Well, there are four slots. Is there a nice combo of CL-60 and resistors that could be laid out. I'm all for functionality AND aesthetics.
EDIT- You guys are posting while I'm writing. Not sure if the "new" softstart board is the same (or close enough) to V2, but I believe that the four large resistors are in parallel in that arrangement, no?
Am I to run 3 CL-60's in series, on one of the resistor slots?
Yes, that's sure from the horse's mouth.
Any opinions on how the Aleph J compares to the F5?
I finally put my Aleph J into my main system and it sings. But where I have it, it does not get a lot of air circulation and it gets a lot hotter than when I had it in my computer room on top of a large table. I am thinking of installing a small--quiet --fan behind the amp.
Any suggestions or recommendations for a specific fan?
On other projects I've used enermax enlobal fans. I ran them at half speed (6v) to make them quieter.
I think that I just need to move the air a bit. I found a few at coolerguys.com. This one looks interesting: Coolerguys Dual Blower Fan Component Cooler with Manual Speed Control (Lite)
They have a few others that might do also. There is another that is a pair of 120mm fans that would either blow over the top or suck air in.
I have limited options wrt placing the amp, Bob, and a fairly significant WAF to deal with.
- Aleph J illustrated build guide
