Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. Moreau
0.1 ohm Re and 5 ohm Rb at +-70V is a bit too thermally unstable for my taste if the transistors are to be insulated from the heatsink. Any mismatch and overbias after signal is removed will be amplified about three times by positive thermal feedback. The mounting needs to be perfect, there is almost no margin for errors. A little too high thermal resistance on one of the transistors and it's instant destruction. :hot:
0.15 ohm might be acceptable though.
Disabled Account
Joined 2007
roender said:
Adjust the OPS bias in order to obtain 18mV over one Re, or 36mV over two opposite Res.
Don't connect drivers to the output node and bias them to at least 80mA or even better at 120-150mA.
sajti said:
I agree with Roender.
I've been trying different scenarios with the simulation, mostly to see the level of distortion with the changes. Without a doubt, the high bias gives the lowest THD but at the cost of serious heat...
I will build it, test it and listen to it with both high and medium bias on both the drivers and the output stage to see what works best.
I've pretty much made up my mind on the MJW21193/94 for the outputs and I've even downloaded the simulation models for these from OnSemi (GASP!). They are not giving me THD numbers as good as andy_c's MJL4281A/4302A models but the results are still within reason - .025% THD. As good as it needs to be I think.
Disabled Account
Joined 2007
Hi sajti,
The NJW's don't have a high enough SOA for my voltage. The MJW's are 3A at 70V. I chose these over the MJL's because they are (1) cheaper and (2) physically smaller - TO-247 as opposed to TO-264.
I have enough of the NJL3281D/1302D to build these but I don't want the in-package diodes. Using 2 for them CFP drivers gives me the tracking (plus the Vbe multiplier transistor).
Disabled Account
Joined 2007
roender said:
MJL,
You make a big mistake thinking that the diode inside slave transistor will follow the CFP driver Vbe. You have to monitor the master Vbe, not the slave ;)
The master and slave will be side by side, mounted on the main heatsink. I did that mostly for novelty - the Vbe multiplier (U19) will effectively track the temp.
MJL21193 said:
Hi sajti,
Yes, but You can use 6 pairs of 0302/0281, due the lower internal capacitances. The only advantage of the 21193/4 is the SOA. But the speed, and the B linearity is worse than X302/x281
Sajti
sajti said:
Looks nice. Low internal capacitance, and the hfe looks linear up to 3A
Sajti
MJL21193 said:
I'll order 20 of each and change my schematic for 5 pairs or possibly 6 pairs.
No spice model available for these. I'll use the 2SA1943/C5200 for an indication.
I'm sorry to say that, but IMHO you have no idea how to read and interpret a datasheet.
How did you come to the conclusion that ST transistors are more linear than 5200/1943 or 3281/1302?
Disabled Account
Joined 2007
What's your opinion of the ST devices? I think they look pretty good for the price - these are actually a little more expensive than the Fairchild 2SA1943/C5200.
I have had good results with the 2SA1943/C5200 in my Patchwork amps, but I want a smaller package for this one with more devices.
