Here the measurements:
Right channel
B+ 146V
Heaters 1,378V
Sinus: input 2Vpp output 4Vpp
Left channel
B+ 142,2V
Heaters 1,364V
Why have different B+ if both channels are supplied with a single 0D3? can be different heaters voltage? can be the reason I hear Left channel sounds louder than Right channel?
I'm sorry for a lot of questions.
TIA
Right channel
B+ 146V
Heaters 1,378V
Left channel
B+ 142,2V
Heaters 1,364V
TIA
Hi!
Seems your linestage is not out of balance.
Also your test with reversing the channels shows that it is not the line stage.
Most likely a bad wiring as Cheah already suggested.
This is the big disadvantage of filament bias, if the tubes differ in emission they draw different currents. This causes a different voltage drop across the primary. In your case it means the difference between the two tubes is about 3mA which is a lot.
When using filament bias the tubes should be tested and the current should be verified in circuit since there is no self adjustment mechanism any more as in cathode bias
Best regards
Thomas
Right channel
B+ 146V
Heaters 1,378V
Left channel
B+ 142,2V
Heaters 1,364V
Best regards
Thomas
Thanks king4joy, switched the channels still same problem Left louder than Right without the lineamp only with TVCs both channels sound the same...what do you think of the measurements?
That to me you have isolated the problem to within the line amp....only between the left and right within the line amp....then try switching left and right within the line amp (for example....tube...power to the tube....and filament....etc..etc...) ...and you will isolate the problem very soon...one can only hope....
Hi!
But the difference in tubes obviously is not the cause for your imbalance, as your measurement and test indicates.
When you reported some lack of bass with the TVC I already suggested that there seems to be some wiring problem. You should fix that
Thomas
Thomas
- Tubes / Valves
- #26 pre amp
