Yes,but im building the standard version so i dont go broke
an mje15003 is 10 and an 2sc5200 is 4 money,but i will try to find something even cheaper like 1-2 money
4 romanian money units=1 euro,plus the fact that in shops they are more expensive and i want to build a 4-5 channel amp
Have you built a mains bulb tester? Sometimes referred to as "dim bulb tester".
Have you read up on the tester and why it helps stop you blowing equipment up?
yes i always use it,but the problem is i dont know hou to make a propre star ground,thats why my projects have been unsucessfull
AX11 with TO3 outputs
Wow can you post the etch file for this one please?
it was done by a friend of my,"Dude" from another forum.
here you go:
Looking on top view, B of MJ15004 was connected to .22R/5W on the output??? Or maybe one of them mounted under PCB?? Just confused maybe i'm wrong....
Yes, there is mistake, MJ15004 must be rotate 180deg.
hello apex sir,
can i use SMD resistors for AX-11
you can
Hello willy can you mail me PCB layout (silk screen,artwork,green masking layouts) for AX-11 to Shravanth.reddy@yahoo.com
coper side is for toner transfer,thanks for warning willy!
Thanks for correct pcb files.
Hi Shravant,
See attached maybe this a bit better than the previous file.
it´s ok - thanks Willy for warning about mistake
Cheers buddy....
- 100W Ultimate Fidelity Amplifier
