Theoretically best subwoofer enclosure
Push-push sealed.
push-push-bipole-explain-png.1196850
Most likely I'm being really dumb here, but how is the box oriented for e.g. the green line in the chart? How would one build this in-wall? Presumably only if you're spanning the wall and pushing sound out on both sides of it? or is it "built in" perpendicular to the wall?
frugal-phile™
Joined 2001
Orientation? How ever you want. Used as woofer you usually want them firing so that you are in the perfect harmony, if a bipole, one driver facing (mostly) forward then the chart sstarts to play a role. What it shows is that as the box width becomes larger wrt to the depth the cancelation decreases.
A monopole loudspeaker the same width but half as deep placed on a wall will behave the same as a bipole out in the room as far as the bipole dip is concerned.
dave
Reactions: 1 user
@MrKlink yeah i've build some but failed badly with a TL sub for my studio. It had really crazy chuffing even at low volume (really weird things going on) so i just reverted it to its original state.
I was really curious if theres an "optimal" subwoofer thats still practical. But that push-push thing looks really interesting (and simple)
I was wondering now:
If i'd build a sealed sub and have to eq it like 10db or more to hit that 30hz for studio work, wouldn't that degrade the whole system because of crazy eqing? BTW I need something for 30-80hz
Hello all its my first post here, it looks like a nice forum to me.
I make also recent a Diy subwoofer with dual opposed 12 inch scan speak discovery drivers, and a hypex FA501 plate amp.
Intern its almost the same as the Sigberg 10D subwoofer, but with bigger drivers.
The box is 18mm MDF and 36mm where the drivers are mounted with bracing and wool, it looks a lot like the Arendal 1723 2S subwoofer.
In Hypex filter design software the sub is tuned @ 22hz+-3db even flat as a SVS SB2000 sub, compared in REW.
I used a umik-1 microphone with REW 2cm away from the cones, to look at the response.
Dual opposed is a good design to make a subwoofer, there are many benefits.
Hello,
A question, why not a pipe? It will not ring for sure, moving mass in vertical direction can't move anything, cheap and easy to build and can be any arrangement as one wishes.
I built this from sewage: Beetlejuice-speakers.409269
At beginning it was bandpass, than sealed, now it's BR.
There is a world discussing SONOSUB.
And of course Nelson Pass ElPipe-O transmission line, for that one I'm sorry that I don't have 5m high sealing 😊
