My design L20D IRS2092+IRFI4020H 200W8R
No the red capacitor exploded 3 years ago. I was sent a new L 30 d anew ! The current problem is the power supply, blown off 6 - 10.000 mf capacitors. Linear power supply are not good for class D power amps. This L 30 D requires a lot of amperes. A big damage.
unable. There is no problem with the linear power supply.
Maybe your power supply is short circuited and damaged. You can simply repair and connect the PCB.
Then install two fuses between DC + 70V dc-70.
Fuse of about 5A
A switching power supply may also be used. However, the damage rate of switching power supply is higher than that of ordinary transformer.
Fuse of about 5A
This is it+ plus a thoroidal. Both burned out. Do you build them ?
The l 30 d has your logo!!! Where can l buy your power supply ???
L30D is designed by me. There is no problem.
You can buy this power board. It supports L30D
USE AC 50-0-50 transformer
In addition, L30D is very geothermal. It is recommended to add fans in summer.
You can refer to the temperature test data of iraudam9
In use, the temperature may exceed 104 ℃
If you don't have an amplifier.
L15d can be considered.
It uses ac36-0-36 transformer. Hardly generates heat. Naturally, it will not be damaged.
Yes but please give to me the link to buy the power supply, will L15 work at 4 ohms ? What power in watts?
I don't know about this link. L15d is very easy to use.
Power is of no use. 2 amplifiers. One 50W. The other is 500W.
Maybe a 50W amplifier is better. The volume is higher.Even more expensive
So what's the use of power.
L15D =IRAUDAMP7S
L30D=IRAUDAMP9
Li todo o post e algo ainda ficou em dúvida.
O L25D pode acionar alto-falantes de 4ohm se alimentado +67 -67 já retificado?
A questão também é sobre alto-falantes de 6 ohms e a mesma tensão de alimentação.
:cop:Translated by moderation:
I read the whole post and something was still in doubt.
Can the L25D drive 4ohm speakers if powered +67 -67 already rectified?
The question is also about 6 ohm speakers and the same supply voltage.
This is me a new design of the AMP. He had since the IR company demo version IRAUDAMP7S-200.
It USES the IRS2092 driver IC, and the IRFI4020H special mosfet output
Its power can do 200 W 8 R (+ 65 V). So I call it the L 20 D.
This version after four times improved. Scrap a lot of PCB to attain my design requirements.
In the test of the wave and test performance he almost and IRAUDAMP7 is same.
And before the same circuit design out, but often appear waveform distortion phenomenon.
I'm glad someone can like this design. It is very small, very beautiful. And a good voice, power is big enough.
Goodnight.
I have an improved version of this circuit and with a size of 115mm x 52mm.
If you want, send me an email (luizcpimenta@gmail.com) and I'll share my project with you.
Yes, if your speakers are not power hungry and you do not listen very loudly.
Good night guys!
I built my L25D, used a DC protection board, a small NE5533 preamp to get the necessary gain, a +64.5 -64.5 VDC linear source.
I noticed that the heatsinks get pretty hot even without signal.
It's normal?
6 ohm speakers.
I'm really liking the sound, it's nothing like the old Class D. It has good bass and airy mids and highs. My speakers are 3-way.
Reactions: 1 user
Thanks for the reply LJM.
But should I worry about this heating?
I wanted to used a power transformer that I already had with me.
The L25D was the first amplifier where I saw the possibility of using this transformer.
I did a test with a 120x120mm cooler on the outside of the case and the temperature dropped considerably.
If I put the cooler, can I be more relaxed about heating?
One note, last night the amp played all night, I left the test cooler off to see if the amp would trip due to overheating or some other problem and I ended up waking up with it playing music beautifully.
