My MOSFET amplifier designed for music
Farther process,testing using +/-35v.
Two 18R/10W resistors instead of fuses.
Input shorted.
Out is open,no load.
Underbiased. 159mV throu 18ohm/10w.
Offset =5mV I think because Vzener=10v still not 12v.
Amplifier is rock stable again!
+/-35v,no protective resistors,fuses in situ.
Bias adjusted for 13mV/0.22ohm=0.059A or 59mA.
Still no smoke,no smell.
I think that is time for cheap speakers connection.
I will connect in series with 10.000uf cap.Yes i will try to keep cheap speakers safe for other amplifiers checking!
Next step,using a pair of more expencive speakers....with caps again.
Finall step,+/-45v.
Stay tuned!
I want to push this a little harder..💣
Connected with better speakers(caps in series of course)
Ok man,I think that I can stamp this as ..TESTED!
Up to now is absolutely stable,no surprises,no smoke no smell no heat,only lovely dynamic music.
To be continued 🤣
Reactions: 1 user
Need to clarify something not to get troubles in others.
In published photos seems that compensation cap C7=22pf is empty.
It isn't!
Because I haven't any through hole type in stock,I have used an smd in the printed side.
Reactions: 1 user
Final test.+/-45v.
Yes,it is rock stable again.
I want to mention that it isn't a good option to use a lower voltage power supply than +/-45v.
If you will use a lower voltage like +/-35v you will expect high distortion playing near to clip levels.
+/-45v bias100mA
Square wave
Is that negative base edge oscillation in #1,313 last picture (input 560mV clip) normally expected?
Hi salas,this is my question too.
In any case I must clarify that I need to repeat this measurement connecting a thiele circuit .
I have to repeat this measurement because no thiele circuit was used.
