900W H-class PA Amp with Limiter
  • tl071 bottom LAYOUT and prtct.png.pdf
  • APEX H900 by coolet tl0 280.35x55.2mm x 3pcs pcb bottom.jpg.pdf
  • 900W H-class PA Amp with Limiter pg255 -900w-h-class-pa-amp-limiter-solidwire.gif
Reactions: 1 user
IR2117 memberikan sirkuit dengan stabilitas terbaik untuk mengemudi MOSFET. Digunakan dalam amplifier konser industri.
IR2117 give circuits with best possible stability for driving mosfets. Uses in industry concert amplifiers.
why does the input zener diode use 18v and 30v?
Joined 2015
It's actually my mistake. I confused C34 with C32. The amplifier in the video looks good. But it showed tests only at 100 Hz. What do you think of the following oscillograms, which were made with my recently built amp? It is powered at +-95V.
Reactions: 1 user
which class , kindly post schematic and build photos
which class ? kindly post schematics and build photos .
Joined 2015
My amp is eengine. The oscillograms above are on the 4 ohm load.
The amp isn't finished yet, it's a work in progress.
