Photo Gallery
I recently got the itch and built another preamp which oddly enough I had the parts for laying around.
Due to it being the eighth one I've built on this design I tend to order lots of parts and have them stashed everywhere...
I've still got to wire the cinemag transformers on the moving coil phono input, but the rest should work...
Very nice build! :)
I think that you use relays for switching between sources. Did you make the circuit board with the relays yourself or is that unit available for purchase?
I also finished, the last amplifier, in the Dracon series, the number four. Same scheme, same PCB, same quality components .
Reactions: 4 users
After a week of waiting for the volume board and a couple of pots, it's finally wired up.
No tubes installed yet, but it turned on so there's no shorts :)
I don't expect any 120Hz hum :) 12V SMPS to DC-DC converter to 400VAC to TL783 linear regulator boards for 340V for line/HP and 350V for phono, 280V DC boost for 6E2/IN12/IN13, 5V for volume and S/PDIF out, 12V for heaters, relays, and bluetooth.
Reactions: 1 users
Look, Ma! It Works! Just like it said in the encyclopedia! LMAO
Not sure I like installing the IN13 tubes with Crazy Glue but whatever, I'm using it not shipping it.
Now I have to make 2U of space in the rack for the damned PSU.
Reactions: 2 users
Joined 2021
Do you ever build something small?
Here it is in the "rack"... I still need to adjust the IN13s - they are set too sensitive. Also, my "EQ" input has a misbalance I have to look for.
The phono stage is nice. Average noise is ~ -77dB. Majority of which comes from the 6N2P input. Next, I will mock up one with LND150 instead to see how that works :)
The IN13 circuit was a kit bought from a Russian guy on eBay who is now "Away" until December 2030
Here's a copy of the schematic.
  • 2022_04_27 10_27 Office Lens.pdf
  • 2022_04_27 10_26 Office Lens.pdf
Reactions: 2 users
