The Pass Pub: The High-End Off Topic Thread
Joined 2010
When I was a kid, I recall reading this stuff in Castilian.
So 'foot' is 'pie'... OK, sense of scale is correct.
But, 'inch' is 'pulga"... ie: 'flea'. I always wondered how the Americans and English could go around measuring things with fleas. I figured they either had Big Fleas, or Small Feet... but we Spaniards changed our socks daily, so we never had fleas on our feet. Weird.
But. why don't we measure amplifier in Joules? After all:
d/dt J = W. Or simpler, 1 watt = 1 joule/sec.
When we measure amplifiers we measure them in instantaneous units... watts... but we don't take into account the temporal (t) dimension. We could have an amplifer that has weak capacitors so it can put a lot of watts in a short amount of time ( think multi channel AVR ) but quits after a bit.... so if we measured joules, we could then use a more accurate description of how work an amplifier can do. It would be more like P(t)
And why do we stick with KwH when Joules would be far more accurate?
Maybe time to go back to forthnights.
Tonight, I feel a bit thrilled,
because - some holes have been drilled...:rolleyes:
Cheers
Dirk :D
to Zen Mod #27536
Good morning! Ouch, 12:30 - time is running...
Yep, copper is exactly the right material for a softy like me! ;)
It can be drilled softly....
But all that stuff has to be handled with care! - I have learned this from the
plastic bag from Mou..er!:rolleyes:
Have a good day
Dirk
