as all mine are
Swapped to a bigger output cap – def made improvement to low-end
how big?
no porn, no glory
bloody greenhorns .........
Its cap-coupled at input and output, so before it goes to the 600:15K's. Is that what you mean?
That's what I mean.
Still like my DC coupled B1 very much.
I looked at the schematics of both the B1 and B1 Korg but I'm not educated enough to understand the similarities and differences. Are they essentially the same circuit? Also, how would you describe the differences in sound? Not asking which is "better" just what the flavors are.
B1 is having no voltage gain
B1K is practically B1 cascaded with small tube ( adding some voltage gain and toobish flavor ) cascaded with another buffer from B1 ( to ensure low output impedance)
so that's it ........ no more, but certainly no less than it was intended ......... making many Greedy Boy having wider Green while listening the music
they don’t sound remotely alike at all. Probably as far apart as you can get. They really don’t share anything sound-wise.
Could you expound on that bit? I prefer a more neutral/technical sound signature rather than a colored/musical sound. I assume B1 is the former and Korg is the latter?
- B1 Buffer Preamp
