Quasimodo results (ONLY)
Joined 2011
I suggest everyone read post #1 of this thread, and heed the thread starter's insistence upon RESULTS ONLY. Chit chat, Quasimodo hardware discussion, lab technique conversation, results comparisons, requests for assistance, Quasimodo mathematical theory, and other things that aren't Quasimodo results tables of numerical data, can go to the general catch-all thread
Simple, no-math transformer snubber using Quasimodo test-jig
Toroidy TS400VA 230v 2x18v
13R
Cx 0.01uF
C2 0.15uF
Ferguson PF1067 400-0-400V 180mA HT 50+53 ohm DCR.
CRC snubber across each half-winding HT
Cx 1nF
Cs 10nF
Rs 1k8
Full-wave ss diode rectifier application. Each half HT winding leakage inductance of 6.1mH at 20kHz measured by soundcard/REW impedance sweep with shorted windings, with self-resonance about 100kHz. Half winding shunt capacitance about 600-620pF measured by resonance frequency, and confirmed by impedance sweep with open windings and self-resonance frequency with leakage inductance test. UF4007 diode across snubber does not change damping.
Joined 2017
Toroidy TS50 VA 2 x 24 V
Toroidy TS50 VA 2 x 24 V, secondaries independent
Cx 10nF
Cs 150nF
Rs 18.5 R
Toroidy TS50 VA 2 x 24 V, secondaries parallel
Cx 10nF
Cs 150nF
Rs 25.5 R
Joined 2020
AnTek AS-3218
10-12ohms
Can confirm, got the same range of acceptable values as thompsontechs for my AS-3218 trafo.
Cs = 0.15uF
Cx = 0.01uF
Rs = 7R5 as measured off the pot (actual resistors of 10R to 12R worked fine)
AnTek AN-3236
Cs = 0.15uF
Cx = 0.01uF
Rs = 16R4 as measured off the pot (actual resistors of 10R to 22R worked fine)
Joined 2010
Toroid Corp of Maryland custom order. Asked for 300VA, 18V secondaries and quiet as possible. Per ZM fashion was build on oversized 410VA core, ES shield, Mu metal band, resin potted.
Results for all 4 transformers showed Rs of 9-11R as measure on pot.
Cs = 0.15uF
Cx = 0.01uF
Rs = 10R
Joined 2008
Hello
Did a search on this thread, the original Quasi thread and on Google…found an inquiry, but no results for a Quasi test
I’m looking for Quasimodo info on the Avel Y236651 transformer?
I used this same transformer in a build I’m trying to solve a noise issue in. Hoping someone else might have resorted to using it over an Antek or similar with the supply shortage.
I haven’t had luck finding info on it and don’t have the Quasi board or ability to use a scope right now.
Any chance anyone has the Quasi information on it?
It would be a big help.
