The latest integrated amp...
I'm just waiting for the nixie in the mail to plug that hole
It has phono plus 3 inputs, a 10Hz 4th order HF filter, 6E2 meters, an OTL headphone amp good down to 32R that doubles as the line stage, and a triode strapped output stage good for about 50W.
Power supply is in a separate chassis (obviously).
I decidedly like the aerial shot
The hardest thing about building this entire thing was soldering the shield wire on that damned RG6! (No I wouldn't have used it if I had ANYTHING thinner at all). I had to use my old school quartz 60W pencil iron. I must build a spot welder
Hi there,
better than my previous SE 300B, above all in bass region !
That's a beauty congrats, different approach on build but very classy...I also see you used CSA ClarityCap they are my favourite cap also love them, so enjoy the music.....all the best
Hi there,
Nice! Could you share some details?
Jim
Hi there,
6336 A double triode in SE configuration
6SL7GT Driver
380V plate voltage
105 mA bias per triode
2 x 9 watts
Is that the toroidy OPT for a 6AS7 that you used?
This is how the small city I live in looks from the skies...
Incredible project, I really wish you success with it!
no surcharge ...
If you order a batch - this is what they told me.
Thanks... After a few teething pains it's up and running now.
Wow - that is amazing!! 27 valves! How many watts go to the heaters?
If everything is on (phono stage only lights up when you're set to phono, power stage is switchable, too so this can be used as a preamp for my other amps) it's ~100W for the heaters.
AirHead
Hello,
you have to order two pieces ( for stereo application ) and 2 pieces is a batch ( Tomasz (--> toroidy boss dixit )
Hello,
Brook12A clones. 2A3 in push-pull. Sounds great with Altecs.
Nice!
...new amp ... four CV4043 (6BW6) per channel, ECF80 in drive/phase splitter... Lundahls output... wanted to try the wood/epoxy combo, looks a bit turtle-ish but I like it... runs pretty hot though.... me happy
- Tubes / Valves
- Photo Gallery
