The BA-3 as preamp build guide
sov
Joined 2016
...What are you aiming for as 100%? ...
Russellc
Aiming for 1volt as in the build guide. Is it safe to increase bias?
Now my BA3 is up to 1V bias. Output 2V from 1V sine wave. I use original schematic except for P1 and P2, they are 1k. Shouldn’t output be 3V? Without tinkering with P3 I have THD% 0,4. It sounds detailed and controlled but there is some something missing. I can only describe it as ”it’s not B1K”. Do I miss some 2H? Du anyone have suggestions how to tweak BA3 to a friendly tone?
How much 2H is reasonable? The big >3H, are the only in my not so sophisticated oscilloscope?
Volume pot before or after is next on the test list.
Official Court Jester
Joined 2003
show me schm your'e using and write what differences in parts are exactly
edit: in fact , there is no need
increase gain simply increasing value of final I/V resistor
you can't change THD Spectra without trying with P3 , and you must do that , to find setting you prefer sonically
if B1 is positive reference to you, you need to find setting with 2nd harmonic dominant and lesser THD overall
Joined 2019
6L6
Moderator
Joined 2010
20VAC will rectify into 28VDC, minus 1.4 from the diodes, giving 26.6VDC. This leaves more than a volt and a half for the regulators (which they need) and would work fine and nothing gets hot because there's not a bunch of voltage to throw away.
And anymore everybody's line voltage is higher than normal, which will give a little extra voltage off the transformer.
The AS-0524 would work nicely as well.
