The BA-3 as preamp build guide
Joined 2019
check with ohmmeter - is center pin of IEC (safety GND ) connected with negative leg , on output side ?
No, doesn’t appear to be continuity there. I’ve attached a pic of the ‘PSU’ in one frame. I originally had planned to connect each SMPS via separate barrel connectors, but my jacks are in contact with chassis. For right now I’ve just wired SMPS’s directly to the cap bank. The barrel jack in the photo is not connected.
Joined 2003
BA3 is warming up at bias ≈890mV. It sounds very controlled and relaxed with fine details. At 90% bias 1V gives 2.5V out. In a few day I will turn up the bias. The FFTs are done with almost no warming up without tinkering with P3s. 1K/1V sine wave from RCA input, so through a 10K pot at minimum resistance. More testing with full bias. Feets and an indicator led is scheduled.
Thank you 6L6 for bildguide, NP for a nice design and everyone else for tributing.
I need to check the bias on my BA3 units, 1 Power amp and 2 preamps. What are you aiming for as 100%? My power amp in Deluxe 5U isn't really all that hot yet. It's quite warm but not "burning" yet.
Russellc
Joined 2019
Waiting on a couple parts, but hope to report back with a finished pre in a couple days!
Thanks again to ZM and 6L6 for your help on this. Still need to finalize wiring and reroute, but it’s up and running. Sounds great!
Hope to build a proper PSU soon, but the two SMPS bricks are working great for now.
Nice build. You have quite the ac filtering going on there.
