Best opamp for I/V conversion? (DAC)
Thanks for the information. I found a PDF and attached here.
The openloop inverting input impendence contribution very little to the closed loop operation while the feedback effectiveness domaining. The CFA OP drops fewer open loop gain when frequency goes up, so it can outperform VFB OP in the I/V convertion.(Even if we use a better VFB instand of AD845,things won`t change too much:just look at open loop gain VS freq. plot.)
Distortion did`t mentioned in this article. If we only focus on input impendence \freq. respond\, we can find a well designed discrete I/V is the best, then comes CFA OP.
So many years have passed since this thread first posted.
  • Low input impedance current-to-voltge conversion circuit for Current-output digital-to-analog co.PDF
Joined 2005
With 8 x 1704K I have 4 Borbely discrete jfet IV stages , it also acts as the output buffer with 85 ma bias on the output mosfets so just a single analog stage for each phase. 10 discrete jfet shunt regulators and the dac board ( not in the picture).
Uses 2sk389/2sj109 , 2sk170/2sj74, 313/2013 mosFets - all the hard to find parts.
over 50 Blackgate caps, teflon caps, nude tX2575 Vishay, silver wire, everything I could find that flat earthers think is a waste of money. With Highdef downloads it’s very , very nice.
So how about current output multiBits delta-sigma DACs? What shall we look at when choosing the I/V stage opamps? All newer DACs are based on this architecture.
For example, what slew rate and settling time should be fine? All the discusses at the beginning of the thread are focus on older DACs.
Audio DACs gave up current outputs (i.e. high-impedance outs like AD1955, PCM1792) and went over to resistor arrays quite some time ago. The resistor values have been decreasing over time (e.g. ES9018 --> ES9038) in pursuit of lower noise so in a sense they've been becoming less current output over that same time. Sure the manufacturers recommend terminating them in a virtual short for lowest distortion but that's a different matter from being 'current output'.
The true current OP PCM179x family have *very* fast current step rise times. Effective RF energy way >100MHz. The newer unity weighted resistor
architecture DACs appear to be less demanding WRT OP edge rates but more
demanding WRT lower OP Z.
T
Just introduce a new option for this.THS3491. CFA.Very high Transinpendence and very fast. If you can accept the distortion of LMH6172, it can be considered.
The classic AD811 still have no alternative at this moment. LME49713 has been discontinued.
We found AD811 didn't sound as good as other options and yes, it was correctly
bypassed. The problem with CF opamps for I-V is that if you wish to place the
first pole of LPF around I-V opamp, as is the usual practice, it will require
an additional resistor feeding into - IP to retain stability. Adding this resistor will
increase the distortion and CF opa's already have higher distortion than VFB
OPA's.
