A guide to building the Pass F4 amplifier
You have to create your own cables that have speaker connections on one end and RCAs on the other. The speaker post that connects to ground (usually the black) connects to the outer part of the rca and the other (usually red) goes to the pin. The speaker connection attaches at your flea watt and you'll need to put a resistor (8, 16 ohms... Whatever is optimal for the amp) across the speaker connections too.
Hello DIY collective,
I am in the process of collecting parts for an F4 build and would like to ask a couple of questions. Before we get to them; my proposed setup will be, ARC Ref 3 pre amp - F4 -speakers or ARC Ref 3 PREAMP - Flea watt amp (TU 8100 PCL86) combined with F4 - speakers.
In the second scenario with the flea watt amp I am not sure how they are conected together and I think the flea watt needs to see a load whereas in the first scenario it would just be connected as normal i.e RCA in, speaker binding posts out.
Could I ask how to go about the construction of a flea watt seeing a load
what parts would be required and secondly how it is connected.
My other question concerns the toroid, I live in France so our eletrical supply is 230V - 50Hz and I am looking to order from Canterbury Windings, I think TM160A is the right one but would like to double check;http://www.canterburywindings.co.uk/standard_range.htmlhttp://
If this is not correct I have the option of a custom build. http://www.canterburywindings.co.uk/ordering.htmlhttp://
If this is my best option could anyone advise me on what would be the specifications for a custom build.
Merci.
Hi Cal,
Thanks for the info, as suspected I will make up 2 cables with banana plugs on one end and RCA male on the other. When you say put a resistor across the speaker terminals is this usually done just across from red to black on the inside of the Flea Watt amp or externally on the binding posts?
This is the rated ouput: 2W per channel into 6 ohms at 10% THD so I shall add 2 X 6ohms
resistors onto my order.
Thanks again.
I am ordering components and would be grateful if someone could check if this is correct to go across the binding posts on the flea watt amp MR5FT6L00-ND
As a beginner I find the choice of components a little bewildering.
Merci.
That is only 6 mOhm, it is very low as such. You probably want something like 8 Ohm or maybe 16 Ohm, depending on what your flea watt amplifier would be happy to see as a load.
Just to give you an idea what this serves for F4 has an input impedance of 47 kOhm which much higher than any typical speaker load that flea watt amplifier is designed for, so you want to put a resistor in parallel to F4 input so that your tube amp thinks it sees a proper load similar to a speaker.
On the speaker binding posts... you can read a bit more about it at the 6moons review of the F4 (6moons audio reviews: FirstWatt F4). From the 6moons article, here's an image of one cableing solution:
Hi Cal,
Thanks again.
