What did you last repair?
Hi Nigel,
I think you will find that liquid solder flux makes your life a great deal easier for stuff like that.
-Chris
Yes it does help.
I also found some flux paste under the chip holds it in place while I make the first solder joint.
The chip is on TQFP 0.5mm pitch so is fun to solder. Lining it up with pcb pads is first challenge, definitely a magnifying glass job.
I start by soaking in flux then run soldering iron along one each of the chip.
That usually ends up with all pins shorted so I put plenty of flux down and use copper braid to remove excess solder.
Administrator
Joined 2004
Hi Nigel,
I normally apply the flux as you've mentioned, and also using a brush to put a little bit across the top of the pins. I tack pins across the package first and check alignment, then run the iron with solder along the row of pins. But, I cheat. I use a 3mm screwdriver type tip. Sometimes the last pins are shorted, but cleaning the tip, then touching the two pins will draw the solder away. Then clean with lacquer thinner. Most times the end result looks like a factory job.
-Chris
Account Closed
Joined 2018
The electrical outlet on my patio had issues.
Plugs wouldn't stay in properly - making the job of mowing the lawn a big job.
A normal 20 minute job, turned into TWO HOURS... because the retaining screws were rusted, and one snapped off in the housing.
Had to drill it out and re-tap for a new 6/32 screw.
I chose the Legrand Industrial outlet because of its durability.
Installed a new water-seal gasket, caulked with some permatex, it's DONE!
Whew!
Account Closed
Joined 2018
That old outlet sure looks beat. Hope the new one lasts awhile!
Yeah, the old outlet was likely put in in the 1970's, not sure, I've only been the homeowner for 15 years now.
It's seen its use, plenty, mainly for the lawn/garden equipment.
The new one is supposed to be designed for "heavy shop useage", such as in busy machine/auto repair shops and such.
I made a little SMD pcb for a A2D AD9200.
It was as fiddle to solder as its on 0.65mm pitch.
Sadly didn't work when connected to the motherboard.
For some reason analogue input was good but no databus activity.
So in desperation I re-soldered one side of SMD device.
Still didn't work.
So re-soldered other side and it burst into life.
I suspect the VCC pin hadn't soldered well and wasn't powering up the device.
I found the trick with SMD IC's is to dab some flux paste beneath them to hold them in place before attempting to solder them. Then line it up exactly. Then just run a little solder up the corner pad to hold it in place. Then solder other side. I then remove any excess solder with copper braid.
80 year old drill press
Walker Turner drill press... was covered with rust and grime, bearings seized, etc... rebuilt from scratch... looks like an alien and runs great. Heavy as hell!
Administrator
Joined 2004
A nice McIntosh MR74.
It went to a different tech who pretty much made it irreparable. We needed a parts unit to replace the destroyed parts (an RF inductor and an RF transformer in the MPX section). Once those parts were replaced we were back to the original fault. But before that, that other tech had tuned the IF strip to 10 MHz! It should be 10.7 MHz of course, and several other silly things. The last part needed was the opto-coupler. Installed that part (a sunstitute) and it began to work perfectly. I'm just going to go over the alignment again to make sure everything is bang on. The customer didn't expec to ever get it back repaired after the first guy was done.
-Chris
Just unplugged the bathroom sink drain with a left over piece of 12 gauge electrical wire, perfect for it, better that the more common 14 gauge.
But as most are probably interested in electronics, the last of that was a satellite receiver that needed a new NVRAM chip. As the only SMD that I have soldered recently, I know that I need some kind of vision aid, as I was mostly on a wing and a prayer. All for nought, as my stupid satellite provider refuses to send me a current subscription card for it, fight as I might.
I'm currently investigating a transformer we have that is (was) running our US spec clothes-dryer. It was fabricated some 14 years ago to use Argentinian 220V, (no grounds), to US common-household 220V.
It did one of those flame-on things...I haven't yet found out if it is a true twin-coil transformer, or just an auto-transformer. Fortunately the laminations weren't all glued together..a conventional E I lams...but the whole core is a whopping 160mm by 192mm per E I lamination...stacked 120mm "high".
Once I get all the laminations out, I'll be assessing the core damage.
---------------------------------------------------------------------Rick.........
