No replacement modules are offered, No help is offered, No technical support, promise after promise.
Just buy the module, let it burn from its own over time. And you have nothing to do.
I dont understand why we buy these?
We buy it expecting good sounding amp.
Also people are probably unaware of support problem as I, my self didn't know that this problem exists with FO at the time of decision to build one...
Unfortunately I have to line up with the rest of you unlucky DIY...
Had the modules playing, but a faulty DAC put out some DC and killed the modules. No support no repair, just boat anchors left. Had two more that got killed by a very short short circuit They are VERY sensitive to mishaps. No warnings , they just blow up immediately. CAVE MAXIMUM.
Hi guys
Thanks for all late relevant inputs. Let me try to clear misunderstandings concerning FO M modules. They've all been tested on specially made test jig before sending out, not even one shipped without QC passed.
Module's PCB is packed with SMD parts on both sides and was never intended to be repairable but replaced by new module only, it was always considered as a single part entity.
Any mishaps or inappropriate use in contrast to instructions, not falls into warranty approval terms. Also last FO M was delivered in 2016, meaning all of them are out of warranty.
New FO M modules will probably be sealed, poured, to clearly indicate that no repair is possible to perform.
What I could offer to all having broken FO M modules is to exchange them for new ones for a fraction of price. Hopefully that would compensate the anger and pressure built lately.
L.C.
L.C.
Well let me add my dissatisfaction to the list. I spent a considerable sum of money on the L modules / power supplies / heatsinks and all the rest. Having built everything I took them to friend of mine who designs and sells his own hi fi equipment so that he could check it out on his test gear. Whilst testing one of the channels smoke appeared from the L module and it promptly died. My friend, who is extremely knowledgeable about electronics and is more than competent, said that he had done nothing unusual to cause the problem. LC's initial reaction was, tough you'll have to buy another module. After more complaining on my part he agreed to repair the module, which I duly sent back to him. That was probably 6 months ago and despite him saying months ago that he would repair it very soon I've since heard nothing from him.
Well let me add my dissatisfaction to the list. <snip>
Bad form. This is taking an ugly turn me thinks...
Well i have received some information from LC with an offer.
Don't know if he will share it with everyone so no further information about that, but i'm very glad that he responded to me and offered a reasonable solution.
If everything will go ok my black 6 channel beast will live on !
diyAudio would draw attention to the rules pertaining to the vendor forums posted on this site.
From the rules:
RULES
From the rules:
RULES
7. The commercial threads are for private transactions between members and other members or companies. diyAudio.com provides these forums as bulletin boards for the convenience of our members, but makes no warranty nor assumes any responsibility regarding unsatisfactory transactions. Normal diyAudio rules about member conduct apply and will be enforced. Please use the commercial sector bulletin boards at your own risk and using your own judgment.
I believe that LC is working on DCoffset and OverCurrent speaker/amp protection. Hopefully soon.
This could solve some issues. with burned output.
Some have reported amp kaput after loosing "return" connection from source...maybe this is due to the amp recommendation of "floating" supplies for best noise performance...
(probably oscillation?)
Guys, tight your signal connections.
Good luck.
M.
and was not your dac killed by spoiling amp?
Nope, no idea about the exact reason. As none of us knows why.
I know how to avoid this. Will be back.
This can happen with other amplifiers to.Some have reported amp kaput after loosing "return" connection from source...maybe this is due to the amp recommendation of "floating" supplies for best noise performance...
Good luck.
M.
Now my only hope is that some Chinese comes out with clone so I can have a replacement module...
he shared VSSA for free, not? you can build it, or any other free amp, there are so many options ...
Good luck.
M.
I'm voting to make a quick pool to see how all you guys did your GND and correlation to burned modules.
So I'm starting - My Amp is built floating as in new manual recommendations.
I have ended with one module kaput
I think it would be great if someone could actually make a pool in this thread, of course if LC agrees!
Beautiful Beast. I like it. A lot. It looks very PRO.Well i have received some information from LC with an offer. <snip>
Is this for Home Cinema?
- Vendor's Bazaar
- First One - mosFET amplifier module
