Check it from schema
thks
There is mistake on MPSA92...
missing mpsa92 and mpsa42Check it from schema
thks
mr apex
what is different between a23 with single op-amp and a23 with dual op-amp?
which one is better?
respectfully
IMHO, Mile is just suggesting to use another type of opamp (a dual one), in case one cannot source OPA. As you can see, only half of the dual device is in use.
thanks mr maxIMHO, Mile is just suggesting to use another type of opamp (a dual one), in case one cannot source OPA. As you can see, only half of the dual device is in use.
Apex Input Selector
Hi, after I have built a completely digital preamp with WLAN control (Controlling PGA2310 with ESP8266 via Browser and Android), I wanted to build a completely analog preamp . Since the P20 is already finished and also the 24V power supply, I needed a analog input selector.
Here it is.
All components according to schematics by Mile and all works fine.
The layout picture from Sprint shows a corrected version with the forgotten wires.
regards Olaf
Here it is.
regards Olaf
Here it is.
regards Olaf
Nice work... 220k must be add for histeresis.
I make copy PCB (SprintLayout 6) and added missing track to relay.
Please change 10k to 220k on PCB.
Hello all,
Regarding input selector with relays i must say that Feeling when turning knob, sound of clicking relays, led's on the front panel... that it is a awesome. Especially when you have little kids, they will love it. They were my endurance testers and after a month of hard testing, clicking, turning knob, everything is working just fine.
After apexaudio posted sketch and idea i wanted to try to build it, made my first prototype and it was successful. You can see that on video that apexaudio has posted here http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-979.html#post5156520
Parts are not critical at all, photocoupler's on my prototype are all diferent, 1-PC817, 2-PC123, and one with no name
People on this forum are saying that magnetic field from relay coil can distort signal, but this is not true. There is no injection into the signal!
P.S.
Sorry for the circuit and pcb that are made with Circuit wizard. After looking at how it looks in Sprint, i have immediately switch to it.
Best Regards,
Predrag
P.S.
Best Regards,
Predrag
According to what schematic?Thanks a lot Mr Mile
regards
Is this a tested pcb?
- 100W Ultimate Fidelity Amplifier
