Hi Quanghao,
Have your tried to implement the ES9038 board with electrolytic capacitors in the power supply instead of Aluminium Polymer capacitors ?
I have an impressions that Aluminium Polymer capacitors are not best use for audio circuitry.
ok, and see schema for this cap!
thanks
Hi Quanghao, sent 475.00 please confirm.
i got it!
thanks!
quanghao
Controls and features
Controls and features:
1. Standby mode.
2. High volume display.
3. 20 x 4 LCD display.
4. Select the 4-way input and display the frequency on the LCD screen
5. Fuse protection - 220 VAC power supply / 5W
6.Turn on, off with remote control or buttons.
7. Simple and appropriate use for DAC chips: ES9038PRO, ES9028PRO.
8. Set up customizable protocols such as: volume, input as you like.
9. Select modes such as filter, frequency, left channel right.
10. Special and unique - Store settings according to your preferences:
A, Keep the big picture to the desired: lowest -100dB, largest 0dB.
B, Select and store left or right channel output - No need to reverse the output.
C, Selectable filter modes: (Pass band): 47kHz, 50kHz, 60kHz, 70kHz.
D, Option: PCM Filter Characteristics
E, Selectable filter modes: (Pass band): 47kHz, 50kHz, 60kHz, 70kHz.
F, Option: PCM Filter Characteristics: Fast, Slow Roll-Off, Apodizing, Hybrid, Brickwall.
1. Standby mode.
Pm sent for refund
Hi Myint67,
You don't want your ES9038 ? What went wrong ?
Hi Myint67,
Not for DAC . for USB refund
@Quanghao
Can I bypass your AC input and feed directly 5VDC somewhere ?
thank you
Pepe
I think it's unnecessary, because the power supply is designed very carefully.
The lt3042 is great!
Therefore, you be careful, otherwise you will kill the DAC. I will not be responsible for doing this.
If you want to take a look at this picture!
Quanghao
Good suggestion. I replaced the first stage 1000uf 10V capacitor with 2 x 16V capacitors with about 12,000uf. The ripple dropped from 600mV to about 45mV before feeding those regulators.
I wonder if I can improve this DAC further by feeding two regulated 9V power supply.
What will make this better than the new OPPO DAC?
James
Previously Quanhao's HQ Reference DAC sound extremely good and I expect the same from 9038.
This is my reason to prefer that one.
James
Hi Jewilson,
This DAC was designed with Hi Fi audiophile in mind but will need some DIY effort.
For example, it uses 7 X LT3042 high performance regulators to feed the ES9038Pro. And you have the flexibility to choose the output analog stages yourself. And Quanghao recommends to use Lundahl output transformer LL1684 for the time being.
The OPPO Dac uses op-amp in the output stages which to my mind cannot bring out the best of this ES9038pro dac chips. Op-amp generally sound harsh and not musical to my taste. (Your milage May Varies). Generally they are chosen simply for their convenience.
But do bear in mind you will need some DIY effort if you choose this DAC from Quanghao.
Here is for Group 2 buy list
1. akltam Option 1.
2.
3.
Hi Akltam..
I believe GROUP 2 has already started..
Please see:
http://www.diyaudio.com/forums/group-buys/300266-dac-es9038-pro-group-buys-15.html#post5005498
Best Regards
CAAD
- Group Buys
- DAC ES9038 PRO Group Buys
