UCD 25 watts to 1200 watts using 2 mosfets
Did t work?, I have get it working.
put smpsadd in sym directory and lib or sub in lib.
regards
I tried that also but this time im getting this error.
Make and test. Then will tell us.
Better use Microcap simulator than Ltspice - for audioapplications its more native.
Ltspice is free and quite executed many schematic with ease. I dont deny but Microcap is a bit expensive.
If the IR2110 executes properly in LTspice then it should be fine. Again i need to manage new libraries for the Microcap and adapting to new software takes some time as well.
You shorted pin 9 and 13. Do not short them! And tie 12V to pin-9!
Your schematic was good earlyer in this aspect. Restore it!
Your schematic is actually dimensioned better than the original which was explosive.
Pin 9 and 13 are connected through a cap and I have removed that cap and added +12V to the VDD but the output not as expected.
im getting this output now what is wrong in here
I did also test with the models, and get strange outcomes, I do stay in discrete comparators because it is more easy with supply.
and I get almost -100 dB distortion with a fase shift version amp with bessel low pass and no analog feedback... The bessel
low pass needs 24 dB octave.
