UCD 25 watts to 1200 watts using 2 mosfets
You are using IR2110 ? Try IR2010
No I use a discrete power comparator for simplicity and to need only one supply,
I have this schematic who do stop when sound is off..
I have many working projects , but they are mostly not UcD based . I don't like UcD - due to it's low loopgain it has heightened distortion , and if increase loopgain - it becomes unstable. I only use UcD for high (>1000W) power subamps, where THD is not the main criterion . And due to postfilter feedback can use less expensive output inductor, something like sendust ring cores....
Here is my old UcD bridge , cliplimiter on board.
UCD can get low HD when properly designed, multipole settings with low pass filters, ucd is self oscillating, best is design d amp who has without feedback already lwo HD, that is challencing but maybe a good step up for high end where there is not much yet.
Here she are.
wow thank you will post some sims soon.
I have a question about the Class D for subwoofer application. Do they have stability issues when either load is not connected or for extreme low frequencies?
The fundamental reason why i want to consider the full bridge and single supply is to avoid the bus pumping effect and i believe this circuit is also with post feedback so the DF could be more.
Did anyone tried this UCD with subwoofers with extreme usage in like PA with good results? I want to drive 21LW1400 from eighteen sound with excellent grip.
I believe full bridge do also not have problems with bus pumping.
here some info.
http://www.irf.com/product-info/audio/classdtutorial606.pdf
In class D clipping sounds worse.
As I told before that during momentary clipping for self oscillating class D, PWM will stop for a moment and only pure DC will flow to speaker. And after clipping, it needs time to restart again the PWM. This event makes clipping in class D is worse than class AB.
It seems you don't have experience at all. :D
Experience is your privilege. Nobody else has it, unless he agrees with you. :p
ClassD clipping sound worse only if you make it wrong. If you do it right it returns to normal operation immediately after clipping. I also fallen to this error in my first big classD amp, but I didn't accept it, found the problem and corrected it.
thanks dimonis for sharing .nice layout .please post schematic of the project.
by the way which topology do you use nowadays of your class d amps??
