100W Ultimate Fidelity Amplifier
Hello
Hello
greetings just did a quick test on FX11 hard hitting bass nice mid and
and treble dc rails 52 volt +/- many thanks to sonal for his wonderfull
pcb desigining and apex audio
warm regards
Andrew;)
Singing. Only testes with +-44V so far. Sounds fine through test speakers. I would like to have a trimmer for offset adjust. Hfe matched LTP and have 4mV on one channel and 20mv of the other. Not really an issue but still there. There also some turn-on noise. Will have to investigate that.
Edit: I used SMD for most of the small caps.
I don't have any more time today to do testing. I only ran it for a few minutes and only at +-44V so I can't say if the little heatsink is necessary.
I could probably play around with different transistors and get the offset lower but a trimmer wound eliminate the issue. If I were serious about this amp that is what I would add. When I have the time I will hook up a bigger PSU and run it through my scope and test for clipping and square wave response. I'll check the heat of the small heatsink at that time.
Blessings, Terry
Nice work, use 100R trimmer instead two 47R resistors (R16. R17) for offset adjust.
