I am asking for the ablatec .....Are you asking about the amp or PCB ?
Is it a diy ??? or you bought it???
The Abletec is the subject of this thread. See post 1 for links where to buy. Used to be $20 at Parts Express since sold out. Now can buy from eBay for $25.
Abletec 900 Watt Peak Class D Audio Amplifier Power Supply 53V DC UL Cul | eBay
Read post 1 because it also has links for the wiring harness and how to add dummy loads to the secondary voltages which must be done for it to run stable.
I have one of these supplies along with a YJ IRS2092 amp that I have never used, and I am wondering if I could use these to power a pair of tactile transducers down between 5-20Hz. I understand bus pumping might be an issue - have any of you measured the low frequency response of the amp/supply?
My latest use of this SMPS is with a nice class AB MOSFET amp. With a simple CRC filter I am getting 1mV ripple at the amp power input. The amp itself now has 0.1mV ripple at the speaker output with audio inputs grounded. Very quiet. The VHEX+ amp is good for about 90w into 8R but has superb low HD and excellent dynamics. The dual monoblock really opened up the sound stage.
http://www.diyaudio.com/forums/solid-state/286992-irfp240-9240-amplifier-simulated-tina-41.html
Since this is a budget oriented thread, the "Un case" you see above costs $8 (2U front panel, self heatsinks for sides, plywood bottom panel ). All connections except CEI receptacle jack are on front for easy access. A users' amp.
If anyone has seen Troels Graveson's main test setup, he has his class AB amp turned around so that the back is facing out for easy access.
You US guys are lucky... I got excited when I saw this thread but the $75 international shipping is a deal breaker.
I get the feeling some US sellers just don't want to ship.
Anyway nice thread. Seems an iNuke NU1000 would be cheaper for me!
The Abletec strikes again, with same CRC (4700uF-5R-4700uF) filter and connected to my new FH9HV MOSFET amp with a single pair of IRF240/9240 I am clocking in at 120w channel steady for 15minutes into a 10R load.
Sine (1khz) wave stress test at 34.5v into 10R load for 15min no problem:
Charlie Laub pointed out to us that the secondary voltage outs need a small but finite load.
Something like a 1 watt 150ohm resistor placed at the secondary voltage outputs will allow the rest of the amp to be stable.
Would anybody happen to have a closeup pic of their abletec with the required secondary voltage load?
Thanks!
Here is the Molex connector, with the 2 - 1watt/150 ohm resistors, that slides on the secondary voltage connector on the PSU. I think that's what you want to see.
now, what are some good ideas for actual working items to attach to the secondary voltage leads?
speaker protection board?
led light show?
USB port?
cooling fan?
pre-amp board?
bluetooth board?
I would like to do something useful with them rather than just waste the power...
so, at least some indicator leds, or maybe VU meters?
anything that can be easily attached?
led light show?
USB port?
cooling fan?
pre-amp board?
bluetooth board?
I have used the two secondary voltages for a computer fan (7.5Vdc) also used an LED with the 5.6Vdc with a resistor to go down to 2.5V. Both worked well, but neither turns off if you used the standby pins, they only turn off if the power is disconnected to the PSU.
You could use the either (with a resistor) to run a BT board or USB port, but a speaker protection and pre-amp boards typically wants 12-15Vdc
I have not tried, nor have I seen where someone tried to combine the 7.5/5.6 to get 13Vdc. Easier to just buy a small torroidal for 12-15V and play it safe.
No idea about the temp probe sensor, I took it off and threw it away on both of mine.
D
Deleted member 148505
led light show?
USB port?
cooling fan?
pre-amp board?
bluetooth board?
You can do whatever you would like with the aux supplies. Just keep in mind that you must still draw some minimum amount of current from them in order for the PS to remain quiet and stable. This is the primary purpose of the power resistors - not just to create heat.
Depending on what you connect, eg. a circuit with a couple of op-amps, there may not be enough current draw and you will still need to include some dissipation.
Dear X,I was going to build an all active 6 channel system with these as the woofer amps, and then probably a class AB for mids, or the TDA7498 (100w) units for the mids, and Sanwu TPA3118 PBTL (30w) for the tweeters. The miniDSP can be powered with 5v to 24v (it has a built in regulator). Most class D amps with BT also have a 5v regulator as the amps can take anything up to 24v typically. Although I wonder how clean the 5.5v is, I may be better off with a linear regulated supply for that critical part as it acts as the preamp.
I'm still going to build D amps for my 8 channel active system and therefore I would like to know how you control the volume of the above mentioned boards that have not built-in volume regulators. Might be recommended boards with built-in pots like this?
https://www.yuan-jing.com/tda7498-class-d-stereo-amplifier-board-100w-100w?search=7498
What is your opinion about these volume regulators/pre-amp?
https://www.yuan-jing.com/pga2311-lcd-remote-volume-amp-channel-selector-board
https://www.yuan-jing.com/alps-moto...nced-x-4-balanced-x-4-channels-selector-board
AUDIOPHONICS PGA-8CH - Contrleur de volume 8 entres PGA4311 - Audiophonics
Do you use soft start modules and speaker protection boards?
Many thanks
Output voltage adjust
If you would like to adjust the outputvoltage of the Abletec SMPS, you should place a resistor parallel to R442. This specific resistor is a SMD resistor placed on the solderside near the output terminals. I used a small 0.125W resistor of 220kOhm, that lowered the outputvoltage from 52V tot 46V.
Wow, this is interesting and useful info! Just happened to see it now.
What might be the possible range over which you can set the main rails?
- Class D
- Abletec 53v Dual Rail 450W Supply for $20
