V-FET (SIT) amplifier production
R9 1000U capacitors in parallel, the output into another distortion of the waveform.
From what i've read i understand that SIT is the best one can obtain from SS. I have a few questions, if you have the answers please reply here but also by PM because i may forget about the thread , not that i not care but i'm looking into alot of stuff and have a very short memory.
1. Are the SIT the same as JFETS, and which is the best one ?
2. What is the best diy class A design for a SIT amplifier ? If not one, which are the few better ones ? I'd still like to know which is the best :). Not alot of power required, though the more the merrier. I can do with 7 watts if need be.
3. Can i listen in the best quality possible way to large symphic orchestras on a 7w class A SIT amplifier using 99db eff speakers ?
4. Can i construct PASS F1 / F2 with SIT ? I'm looking for the best way to feed some Beyerdynamic DT 880 with 600 OHM impedance, but also some HD650 that i didn't yet purchase.
Please take your time,
Roland
The one and only
Joined 2001
SITs are a special type of JFET that is more triode-like in its curve,
having what we would call a low Drain impedance.
Single-ended Class A would play well to the strengths of SITs, but they
can be made to work in most varieties of circuits.
3. Can i listen in the best quality possible way to large symphonic
Yes you can.
Similar to F2 would be my choice.
:cool:
