Vacuum Tube SPICE Models
See post 1090 -- the LTSpice syntax is a bit different from MSIM -- you need curly brackets.
I used these parameters:
KG1=0.00230261 kp1=-6.471 kp2=31.77 kp3=-5.93e-6 kp4=0.1736 kt1=50 kt2=0.08 kc1=6.721e-4 kc2=7.588e-2 kc3=1.708 ks1=3.462e-6 ks2=3.451e-4 ks3=-1.169e-2 kcs=0.09196 ecref=0 esref=250
I don't have any screen current data for the tube.
Rethinking this -- specify IG2 as a function of Vak/Vg2 and Vg1. A little less "phenomenological"
I could use more data for Vg1→ 0
Hey Gang, does anyone have a 6N7 model they would like to post for me?
I have been using one section of an ECC33 in LTSpice to model the two sections of a 6N7 in parallel, it's the closest thing I have but I would like a real model of a 6N7 before I rip my amp apart.
I want to thank Thomas from Vinylsavor blog for giving me the idea of trying a 6N7 to drive my 6HJ5 amp. I plan to current source the plate @10mA and use a blue LED on the cathode.
Thanks,
-bird
I found the model below among my models, but cannot guarantee accuracy.
Code:
.SUBCKT TRIODE_6N7 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=3.6P  CGP=2.6P CCP=4.6P RGI=2000
+ MU=37 KG1=1680 KP=340 KVB=396 VCT=3.906E-5 EX=1.32
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Looks accurate enough to me but I can't seem to get it to work in LTSpice correctly. I mean I don't get any errors but I am getting weird readings like the same voltage at the cathode is appearing on the grid in a simple common cathode gain stage. The model looks different then the ones I am use to so maybe I need to change something in the txt file?
Code:
* 6N7_GE Twin triode power amplifier LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.059444mA
* Traced by Wayne Clay on 9/6/2007 using Curve Captor v0.9.1
* from General Electric data sheet
* Note: Positive grid region not modeled
* Inter-electrode capacitances are guesses
.subckt 6N7_GE  P G K
    Bp  P K  I=
+ (0.0114397703m)*uramp(V(P,K)*ln(1.0+(-0.5370300777)+exp((7.042163077)+
+ (7.042163077)*((40.286562)+(476.0498871m)*V(G,K))*V(G,K)/sqrt((1.127269255)**2+
+ (V(P,K)-(-24.1176161))**2)))/(7.042163077))**(1.290144231)
    Cgk G K 4p
    Cgp G P 4p
    Cpk P K 3p
.ends 6N7_GE
I've just added a diode model to give some semblance of grid current and to insure covergence. Didn't notice it wasn't there before. :dunno:
Code:
    Bp  P K  I=
    Cgk G K 4p
    Cgp G P 4p
    Cpk P K 3p
    d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6N7_GE
Code:
    Bp  P K  I=
    Cgk G K 4p
    Cgp G P 4p
    Cpk P K 3p
    d3  G K dx1
.ends 6N7_GE
I just updated the model, Thanks again!! :cheers:
This is related to 47 pentode model.
I took your advice and end up with the following model
.subckt type47 1 2 3 4
+params: KG1=0.00230261 kp1=-6.471 kp2=31.77 kp3=-5.93e-6 kp4=0.1736 kt1=50 kt2=0.08 kc1=6.721e-4 kc2=7.588e-2 kc3=1.708 ks1=3.462e-6 ks2=3.451e-4 ks3=-1.169e-2 kcs=0.09196 ecref=0 esref=250
E1 7 0 Value={V(1,4)}
E2 8 0 Value={V(3,4)}
E3 9 0 Value={V(2,4)}
RE1 7 0 1e12
G1 1 4 VALUE={(KG1*V(7)+((kp1/(kp2+v(7))+(kp3*v(7))+kp4)-KG1*V(7))/(1+EXP((KT1-V(7))*KT2)))*((kc1*V(8)**2)+kc2*v(8)+kc3)*((ks1*V(9 )**2)+ks2*v(9)+ks3)*(1/(1-kcs*(V(8)-ecref)*(1-V(9)/esref)))}
RCP 1 4 1e12
C1 2 3 2.4e-12
C2 1 2 3.9e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.model dx d(is=1e-9 rs=1 cjo=10e-12)
.ends
However, when i tried to simulate, it ran very slowly.. i don't think it works? Where did i go wrong?
  • 47 Plate to Grid Feedback.asc
