Hypex DSP module(s)
A simple way is to just load up REW. Make or load a measurement, add some smoothing and then just hook up the EQ thingy, input your desired house curve and calculate yourself some EQ filters.
Just pick any of the constant Q biquad devices as equalizer like for example the DCX2496.
You can't load them directly into hypex software but you can copy the Frequency, Gain and Q from the EQ Filters tab and input them as PQ filters.
I plan to use DLCP+input_board+control_board+nc400*2 as digital stereo amp/preamp.
(coax spdif and optical inputs only).
Connected all components (ch1=left,ch2=right), but no sound on any input.
As i understand, by default the Unity is a routing input channels onto output channels.
PS I updated DLCP to bootloader 2.0 and to firmware 2.3.
please help
I'm running a speaker in mono now and want to send both channels to it. But I'm not able to change the routing. It's stuck. Anyone?
attachment.php
