dadod, your feedback ratio begin to decrease at 1KHz. No surpise you don't see any difference with feedback impedance.
Everything was explained about this simulations in my previous posts.
My purpose was not to criticize your design, but to help-you to understand what a CFA is.
Unless you achieve to add stages faster enough to introduce no openloop bandwidth reduction, you cannot do-it. CFA are in the spirit of Kartings, you cannot design them like a limousine (VFA way of thinking).
With the actual available device's speed on the shelf, you need to get a flat openloop bandwidth up to 10KHz. That is the goal. After this, you can try to add complexity in order to reduce distortions, taking care to not destroy original speed, or adding unwanted poles, not good for stability.
Sorry Esperado, I am talking about something you don't understand so we are done here, if you want to learn more about my amp ask the question in my thread please.
diyAudio Member RIP
Joined 2005
but he can afford to be deaf if need be
interestingly "phase denial" is very common among recording engineers - mic placement, analog signal chains don't always capture "audience perspective" (close micing drums) or try to preserve polarity throughout the recording/mixing/mastering process
As is, for many of them, the denial of, and refusal to be tested for, their hearing loss.
That was one of the moments of particular candor in the remarkable story in Rolling Stone (the audio journal of record) about Jimmy Iovine --- his admission of difficulties with his hearing, despite his assertion elsewhere in the article that he can hear what is wrong with something from a block away, or words to that effect. Much better than the strawmen of audio engineering, walking around in their white lab coats and holding clipboards.
Not to mention it is so easy to reach this stupid "design goal". Just load the VAS/TIS with a resistor and one can trade loop gain for open loop bandwidth.
Just as easy as it is to add a little DC Vos positive feedback to make almost any amp 120dB Aol at DC. Even the Otala amp, a very large resistor from the output to the appropriate point and suddenly the low OLBW goes away.
Sorry, dadod, YOU don't understand what is a CFA. and your amp demonstrate-it*. I have still a lot of questions about them, but I work on this topology since 1970**. And you ?
* I don't say it will sound bad, do not confuse.
** With the same errors at the begining.
Or use a local NFB around VAS/TIS, but in my CFA I don't do anything of this and have flat loop gain of around 80 dB up to 20 kHz(or open loop gain of 108 dB). All this with the proper compensation, and that is the amp Richard is saying it sounds so good.
In think Complete human hearing audio region is very critical ,
from quality definition of lowest bass spectrum ,via middle spectrum and up to highest treble spectrum .
There's definitely a region of our hearing that is more sensitive. So stacking our deck in that region makes sense to me. And, well, a low OLB integrator having the same loop gain at 20 kHz (or thereabouts) as a high OLB integrator does exactly that (and we're never doing WORSE over that region).
banat, first a personal remark. There is no 'more correct' technical justification to prefer ppm distortion numbers, increasing feedback at lower frequency and sacrificing coherency all over the listening bandwidth than to prefer the contrary.
We don't have yet sacred threshold numbers in VFA/CFA religions.
The only way I know is to try to figure-it out, with a freethinker's position , listening and listening again, choosing our poisons. As long as it is done in an honest attitude.
About class A, my personal position is it a waste of energy and heat for nothing. Not complicated to have a class AB amp, working in class A at normal listening levels and turning only into class B during very short peaks at high listening levels. I even find it give a enhanced feeling of dynamic.
Concerning the distortion numbers we can achieve with a very simple CFA, even in class AB, they are, on my opinion, yet well under the minimal requested value if correctly designed.
Some prefer impressive distortion numbers with sinusoidal signals? OK, go to VFAs.
Some prefer slew rate, extended phase coherency, extended constant feedback ratio etc... go to CFA.
I prefer class D for my subs, because it is low distortion, high efficiency, and that the evils of Class D (switching frequency) is far away from the range of the boomer. I prefer VFA for my bass/low medium, because I can benefit from both a high open loop gain, and constant feedback ratio in its range. I prefer CFA for my high medium tweeter...definitively.
As i prefer to keep very bad educated "stupid" people in my ignore list.
Esperado
Thanks for all of yours answers !
dadod, it seems you didn't understood my attempt. Neither try to understand what I said about my way to explore-it.
I was not criticizing your amp and don't want-you to be crossed against me.
I was just trying to explain why you don't see any difference with high or low impedance of your feedback path: your bandwidth is not high enough to see-it.
And you asked the question.
Your amp is a VFA with a IPS topology of a CFA. Nothing wrong as long as it sound good, but is is like this.
My English is not very good, that's why ? No need to be paranoid, neither to put yourself on the defensive. You are free of your choices.
By the way, I said your preamp was very brilliant, don't I ?
One day, when I'll have the time to put it together, I'll show you a 2 pole compensated VFA (in fact, a slightly modified Lin topology) with the same high ULGF as yours and the same 80dB loop gain at 20KHz. Perhaps that will be the proof you need to understand there's nothing really special in your so-called CFA. Not the same SR, of course, but still 20x of what's required to avoid TIM.
I couldn't care less of Mr. Marsh's (or anybody else) CFA SQ comments, as long as they can't prove they can tell a VFA from a CFA in a DBT. Until then, the sacred cow is naked.
Dadod, I just simultated your amp with 5500/220 (Yellow) And 550/22.(blue) in your feedback.
How can-you say feedback impedance has no influence ?
That will never happen, the years of listening are above reproach questioning them is just something that can not be.
scott, once again the question your answered was flawed (as habit).
Can-you make the difference between one of the AD or PMI OPAs and an other one ?
Probably yes.
Can-you name-it just by listening ? Surely not.
Now, if we make the same blind test between many pairs, VFA vs CFA and you note for each pair your preferences, is the statistic result can have a sens ?
Do-you think that we are all under some hypnotic influence of Mark Alexander ;-) ?
Disabled Account
Joined 2012
No one knows exactly why CFA sounds better. The comments about what is audible is overly simplistic. A few paragraphs about phase and the ear is so old as to be Almost worthless as an aurgument. When we discussed this last year I put up a new book on hearing that was a summary of all the new info on it. JC bought it and started reading it. Hearing is much more complicated than a F-M curve or some phase data vs freq sens. Just as vision is much more complex than a few basic observations read off a chart of characters at a distance.
Eye glasses do not correct for everything in the world of vision perception and F-Munson curves, freq response, THD etc do not describe the whole of hearing perception. Both senses are much more sophisticated.
This gentleman's debate on why CFA or even why does DAdod's amp sound so much more real to sounds we hear and know isnt going to be solved this way. But setting aside the hearing or not of the amp.... it is a unique solution which combines the best of both CFA and VFA and should, IMO, be something to learn from.... he took a fresh 'open' look and thought outside the box. Nice job! So, let us at least try to understand it better. Maybe B.Cordell or others will find it suitable for inclusion in their book(s).
THx-RNMarsh
