test PCB only. done some modification(picture shows) and now its run good
Supply +/-45V DC (+/- 47V DC max.)
fsw=@170khz
filter= used ETD29 {@80uH}
Temp:
MOSFET - max 55 deg. at 2.6R load on Full drive
FILTER - 37 deg heat only
added DC offset preset
Application:
Active Sub woofer
Active Mid bass
MANOJ
fsw=@170khz
Temp:
Application:
Active Sub woofer
Active Mid bass
MANOJ
fsw=@170khz
Temp:
Application:
Active Sub woofer
Active Mid bass
MANOJ
Sir Manoj
Test pcb only means?
Hello manojtm , can I have a circuit for this amplifier?
AUD1000SD or AUD200U
MANOJ
Sir Manoj
made only 3nos. PCB for testing. i need to redraw again (b'cz some components fitted on solder side)
MANOJ
MANOJ
will you redesign it with large heatsink?
and if yes then will all the protection will be onboard?
Sabir
Hi sabir,
Yes. I planed to use 3mm thick and 80x80 mm L shaped aluminium
( picture shows 6mm thick one )
Hi sabir,
Hi Sir Manoj
sounds cool.. and what about protections. I am interested in your projects. i have some questions. do reply to pm
Sabir
Hi Sabir,
AUD200U
Protection:
Temp: used KSD9700 85deg. NC type Thermal switch
DC Protect : detect @2.7V 5ms 10A Relay and ON delay 3.3sec
OC Protect : @18A sense @45ms
MANOJ
hi Sir Manoj,
do notify me when this amp is ready.. design it as a beauty.
Sabir
AUD200UHi,
MANOJ
Hi PRAPORSHIK,
AUD200U
it is old simple class d amp using MOSFET irf9540 and irf540 with one comparactor ic.The circuit i modified and to get best result
<90% efficiency
MANOJ
please show diagram
Hi! What changes have You done?Hi,
old design
MANOJ
hi sir please post the protection side
Hi Stewin,
Definitely i will do. pls give more time
MANOJ
thanks sir . i,m waiting. meanwhile my ucd project with protection but it has smd parts.
gtG ucd 1100 rev 3.0 hp with protect semi smd pcb bottom.pdf33.6 KB · Views: 205
gtG ucd 1100 rev 3.0 hp with protect semi smd top components clear.pdf23.9 KB · Views: 196
gtG ucd 1100 rev 3.0 hp with protect semi smd bottom components clear.pdf24.1 KB · Views: 208
gtG ucd 1100 rev 3.0 hp with protect semi smd bill of materials.pdf45.6 KB · Views: 220
gtG ucd 1100 rev 3.0 hp with protect semi smd bottom.jpg258.1 KB · Views: 866
gtG ucd 1100 rev 3.0 hp with protect semi smd pcb top.pdf34.1 KB · Views: 211
- Class D
- My class D amp
