My class D amp
test PCB only. done some modification(picture shows) and now its run good
Supply +/-45V DC (+/- 47V DC max.)
fsw=@170khz
filter= used ETD29 {@80uH}
Temp:
MOSFET - max 55 deg. at 2.6R load on Full drive
FILTER - 37 deg heat only
added DC offset preset
Application:
Active Sub woofer
Active Mid bass
MANOJ
thanks sir . i,m waiting. meanwhile my ucd project with protection but it has smd parts.
  • gtG ucd 1100 rev 3.0 hp with protect semi smd pcb bottom.pdf
  • gtG ucd 1100 rev 3.0 hp with protect semi smd top components clear.pdf
  • gtG ucd 1100 rev 3.0 hp with protect semi smd bottom components clear.pdf
  • gtG ucd 1100 rev 3.0 hp with protect semi smd bill of materials.pdf
  • gtG ucd 1100 rev 3.0 hp with protect semi smd pcb top.pdf
