MOSFET Amplifier IRFP240/IRFP9240
Come on Juan post the cool pdf:)
yes I didn't think about sorry here we go guys :up::D
the relay is a common 12V 16A contact manufacturer part number is G2RL-1A-E-CF DC12 or DigiKey search engine part number Z3080-ND
the terminal contact where you see the letter "woofer" part number is 609-3927-ND
at the moment of this writing, for what I read in this section of the Apex HV23 the coils is 15uH ?
Juan
  • Apex NE555 foil.pdf
  • Apex NE555 protect 2015.pdf
  • G2RL.pdf
Juan
Nice pcb, coil is not 15uH but 15 turns on 10mm dia with 1,5mm wire.
2SA1837 hot
I made a pair of this project, and it sounds great. I´m in the process in adjusting the bias, and secceded I think. Hit around 14mV 5 minutes after startup. Without input, actually while adjusting the bias (or waiting for it to stabilize), I put a finger to the output devices IRPF9240/240, and the temp were OK - i guess around 40-50 degrees celsius - but the 2SA1837 is a lot hotter than the others - but not hotter than I could hold my finger on it. I guess around 60-70.
Is this critical/a problem, or am I just being paranoid? :)
Whether it is critical or not, I still think its odd that the driver tansistor(s) i running hotter than the actual output devices.
All IRFP9240/240 and 2SA1837+2SC4793 is on the same heatsink.
VAS transistors 2SA1837/2SC4793 work in class A with 30mA bias and must be hot.
Holton AV400 vs Apex HV23
Gooday all,
I intend building an IRFP 240/9240 amp with three output pairs per channel. I have came across the Holton AV400 and Apex HV23 which both uses the vertical fets and the power is closely related. Now, the question is which one to build ? It will be used in Hifi and needs have good sound. The load are 4 ohm speakers. I have a choice of two transformers, 2 x 300 VA 70Vdc or 1 x 800Va working at 50VDC. I tend to move towards Apex's amp as I have read some people had problems with the Holton amp due to bad documentation. All help will be appreciated. :)
i have build before the av400 amplifier and everything are ok. Now i am building another 4 channels Av400 so i will have totally 6 ch amplifier to tri-amp my speakers. the documentations for the av400 are fine. if you are designing and making your own pcb's i have the av400 pcb already designed with Orcad so if you want i cant send it to you.
BC517 equation
You can draw schematic from pcb layout, it's simple circuit.
Mr. Mile, there are some questions about this psu7,
1. is there any equation BC517 .. I is difficult to find in this area.
2. if I replace Relay with 24V / 5A, what should I change.
please help sir,,
please help sir,,
Boedy,
1) Try two BC547 (or BC548) in a darlington configuration;
2) Replacing a relay for 16A with another for only 5A will reduce the maximum power your system will withstand. Hence, maybe it won't last such a long time.
