Pass DIY Addict
Joined 2000
My cheap little DCB1.
Very cool implementation! I like the minimalist approach and use of materials.
The external PSU based on LM317/337.
very nice !
F5TV3 monos finally finished
Here are some pics and details of my F5TV3 monos.
Bias per Nch/ Pch is currently at 2.4A per ch and heatsinks run around 44F above ambient. Should be no problem meeting design target of 100W Class A when bias is turned up to 2.5A. Voltage under present load is 46V.
Antek transformer mounted on separate sub chassis that rests on its own feet.
Toshiba Mosfets used.
Heatsinks USA heatsinks 4.5in x 20in on each side.
Store boards were drilled to accept 14AWG teflon coated silver copper wiring
No turn on or turn off noises or hums at all. Dead quiet. Very transparent relaxed sound after only 30 hours of use.
A big thank you to Nelson Pass for sharing his design on diyaudio and to everybody here who have patiently answered my many questions.
Nash
Nash
transistors clamped,.
Thanks Walter. I learned a lot from studying your build in which you discussed the merits of clamping the Mosfets.
Nash
Aleph 5 (No1)
Since 2009 to present I've made few Nelson's amplifiers.
Thank you Mr. Pass!
The first Aleph 5 is assembled from recycled electronics, housing is not very nice but it is robust and functional, it’s completelly DIY.
Power supply is dual-mono, 2x350VA xformers, CLC 56mF+2,2mH+ 56mF (total 448mF) .
In the meantime there was some improvements over the previous version (replaced transformers, high quality passive components, etc.)
More pictures here
Thank you Mr. Pass!
More pictures here
Aleph 5 (No2)
The second, also Aleph 5, in the HiFi2000 housing, power supply 800VA CLC 100mF+10mH+100mF
More pictures here
More pictures here
First Watt F5 (No1)
The next two are First Watt F5 classic.
First, HiFi 2000 chassis, power supply is dual-mono, 2x400VA CRC 33mF-0,47-33mF (total 264mF)
More pictures here
More pictures here
First Watt F5 (No2)
And the last, F5 classic, power supply is dual-mono, 2x150VA 33mF-0,47-33mF. Housing is DIY.
More photos by phases of construction:
housing construction
assembly housing
assembly and testing
Finish
That's all,
regard
P.S. I apologize for spelling errors, blame google
assembly housing
Finish
That's all,
regard
More pictures here
I apologize, I forgot to link to images for F5 No1... here they are ...
Fugly!
though , I see you skimped on XLRs ......
You always flies at half of my writing
I have nothing balanced in the system, I don't need them for now
Pass DIY Addict
Joined 2000
Wow - that is some construction - using gold coins as mosfet washers ;-)
Patented by Zen Mod
Zocky, did you use CMC RCAs on the Aleph 5?
Yes, it's CMC RCAs, they are great.
More pictures here
I believe there is enough place for motor-runs , left and right of xformer
ZP,
what's the reasoning behind the completely open bottom panel and the (odd attached) sub-chassis ?
(Most effective way to cool electrolytics is at the ends, btw. Some folks even use thermal goop, in particular with stud/nut mount cans)
Yes, there is plenty of space but do not know if it is necessary, the amplifier has excellent sound and without motor-rans.
This shall be decided our friend Woland and his junior ... propose to him when you see him.
- Pictures of your diy Pass amplifier
