100W Ultimate Fidelity Amplifier
A14 Prototyp Board
Here we are.
Lots of errors eliminated and etched a prototype board (picture fresh from etching).
So we will see in the next few days if everything is correct.
regards Olaf
A14
it sings! :D
I had a stupid mistake. It took me a long time to find it.
But now it does.
The quiescent current is easy to adjust with the potentiometer. For the test, I chose 50mA. The offset is less than 2mV.
The sound is fantastic. An amplifier with which you can hear rock and dance and classical music equally well. Is simply fun.
Crisp and dry bass. Breezy Heights, very transparent and detailed. As always - the last built amplifier is the very best.
Tomorrow I will make the finished foils for etching.
regards
Olaf
Ok, it's already tomorrow ... (at least in Germany :)).
Here are the print files and a schematic with the changed values. The transistors are numbered. So they can be found better in layout
regards
Olaf
  • A14_ComponentView.pdf
  • A14_Mirrored.pdf
it sings! :D
But now it does.
regards
Olaf
Nice work as usual, thanks for the files,
